Question about Sony Video Cameras
Sony dcr-hc21. Touch screen won't respond cost to fix
Tony Parsons
  • Sony Master
  • 6,263 Answers
Fixya does not provide any kind of repair service. Contact your local service centre
Posted on May 23, 2019
5 Related Answers
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: SONY DCR HC21 touchscreen buttons/functions suddenly not working
yes, seems its flexible wire that is bad.
Posted on Jun 21, 2009
Anonymous
  • 9 Answers
SOURCE: Handycam DCR-HC21: LCD touch keys does not work
try alamocamera.com for repairs
Posted on Jul 30, 2009
Anonymous
  • 3 Answers
SOURCE: buttons on touch panel of my DCR-HC21 Sony stopped working.
I have a sony handycam dcr-hc30 and the buttons on the touch screen stop working ....any solution to this problem
Posted on Nov 30, 2009
larry james
Larry Stiles
  • 301 Answers
SOURCE: I have a sony handycam and I cannot calibrate my
The touch screens in these can shift. Can you rotate the screen and get the screen to work? if so it's possible if your skilled to recenter the screen then resecure it. of course you might end up having to replace it. I have replaced more of them than recentering them . Larry's Electronics [email protected]
Posted on Apr 24, 2010
sonyfsd
Nasir Muhammad
  • 228 Answers
SOURCE: I reset my Sony DCR-HC21 and now the LCD screen doesn't respond
there is a problum in side the camera one is ffc whicis connect the lcd to main board if no then lcd it self having problum because thes tuch switches are in side the lcd please go to your nearst sony service centre & fix this problum
Posted on Apr 29, 2010
My sony handycam dcr-hc21 won't respond to touch on the touchscreen anymore. I can't rewind, play, etc. I also don't know where the reset button is on this model, or how to calibrate. ...
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at a reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 25, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
My handycam dcr hc21 screen wouldn't work when you touched it. i followed the directions and reset the camera. now the screen has the reset screen and i can't refigurate it. please help
Hi Alisa,
You have broken fine flex cable between your screen and board/PCB causing your touch screen ****** to work. So first of all you need to replace the cable first with new one.
Regards
Sep 16, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
I have A sony dcr-hc21 and i need toknow how do i fix the screen that you put play? is that when i try to put play i can so i can't see the things i record
The flexi-connector flexible pcb connector which provides power and drive to the LCD screen is almost certainly fractured in the swivel bracket which holds the LCD Screen. This is available as a spare direct from Sony.
Jun 09, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
I reset my Sony DCR-HC21 and now the LCD screen doesn't respond to my touch. It's just stuck on the date/time screen. I tried to do the calibration, per the user manuel, but I can't get to the calibration...
Apr 29, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
The touch screen buttons not working. I can record movie.
HERES SOME HELP AND SOME ADVICE FOR YA............touch harder!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Video Cameras Logo
135 people viewed this question
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
