Question about Icom Radio Communications
Need icom IC-F3003 Programming software - Icom Radio Communications
Posted by Sylvester Piniau on
5 Related Answers
Anonymous
SOURCE: icom IC-F1020 and icom ic-f3
cqham.ru
Posted on Apr 13, 2008
Anonymous
  • 55 Answers
SOURCE: Squelch adjustment on IC-F21
Is it a UHF radio or GMRS/FRS?
Posted on Nov 05, 2008
Anonymous
  • 17 Answers
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Posted on Feb 02, 2009
Anonymous
  • 8 Answers
SOURCE: If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Posted on May 02, 2009
Anonymous
  • 12 Answers
SOURCE: ICOM IC-F21 (400-430MHz): Programming problem
When programming the radios the green light will flash when uploading or downloading data. The red light flashes when the battery is low. Maybe they are happening at the same time. As for the error message I would need to know what it said. Carl
Posted on Sep 14, 2009
Icom programming
I looked up ICOM 2710 on the icomamerica.com web site and found ICOM IC-2710H which is a ham radio transceiver.
Jul 14, 2014 | Radio Communications
Can you change the squelch setting on an ICOM F61V
The squelch setting can only be changed with dealer programming software. A Manual for this radio is available from http://www.icom.co.jp/world/support/download/manual/pdf/IC-F51V_F61V_3.pdf
Jul 06, 2014 | Icom IC-F61V UHF PMR Handheld Transceiver...
Cloning CS-F50 using usb port
Do you have a USB programming cable for the radio? If not, get a USB to serial adapter and plug between the computer USB and serial programming cable. Adapter driver will help with the interface.
Jun 09, 2014 | Icom Cs-f50 Programming Software Ic-f50...
Resetear icom ic f24
Tienes que usar un programador y un software.
si necesitas el software me avisas.
tienes el programador?
Mar 19, 2014 | Icom Ic-f14 / Ic-f24 Programming Software...
Icom f-10 vhf,wish to programme,have speaker jack plug and software,how do you get the radio into programming modr??????????
Go to ICOM's web site and down load the free software. Otherwise, download the manual there in PDF format. You can go to RadioReference.com for more information.
Jan 28, 2010 | Icom IC-R5 Handheld Scanner
1 have a icomf3s-3 32 channeli can ony see 16
Hi, the problem is you only have 16 channels programmed in the radio. you can program the full 32 if you have- the software, http://hamradio.online.ru/ftp/dw.php?icf3f4.zip . And the programming lead- http://cgi.ebay.co.uk/USB-Interface-cable-for-ICOM-IC-v8-Radios-6-030_W0QQitemZ330356207021QQcmdZViewItemQQptZUK_ConsumerElectronics_SpecialistRadioEquipment_SM?hash=item4ceac3adad&_trksid=p3286.c0.m14
Hope this helps.
Aug 16, 2009 | ICOM Informatique Icom Radio IC-F3, IC-F4,...
My IC-F21 portable radio wont communicate with each other. is there a reset?
You will need the programming software to check all settings of the two radios. If both radios are programmed the same then you need to run tests on why they wont communicate to each other. Unfortunatly there is no "reset" for the radios. Carl
Jul 19, 2009 | ICOM Informatique Icom IC-F21 16ch UHF...
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Programming issues with Icom F21
What you have is a programming issue. The radios need to be "cloned" so they will all work together. You can buy the software on line for about $65.00 then you can change frequencies when ever you want.
Nov 17, 2008 | Icom IC-R5 Handheld Scanner
Radio Communications Logo
391 people viewed this question
Top Icom Radio Communications Experts
Perry Mellott
Perry Mellott
Robert McClure
Vincent G
Vincent G
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
