Question about Refrigerators
Why is there water leaking from bottom of refrigerator section of subzero?
Posted by Julie on
Dennis
    Top Expert:
  • 1,052 Answers
Frostless freezers will go into a defrost cycle periodically and the frost that accumulates in the freezer section melts and runs into a pan under the refrigerator section, through a drain hose. If this hose clogs with crud (common) the melt water can't drain and leaks into refrigerator section (or it was designed this way so as to prevent refreezing.) As the drain is clogged, thd water builds up until it overflows to floor level.
You need to locate the drain in bottom of the refrigerator section (usually near the back where its hidden from view) and clear it out. (Use care as its usually only a vinly hose and can be punctured or slipped off its connection).
Posted on May 22, 2019
Gustavo Fajardo
  • 24 Answers
Is condensation. Look for a tray that is full of water inside the unit. Compressor. Or check gasket on the bottom part to see if it’s bend
john h
    Top Expert:
  • Refrigerators Master
  • 23,424 Answers
Looks like drain is clogged
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: subzero 550 water drain in refrigerator section backs up
The problem is that the water freezes in the drain, either because the door is not sealing good, it's open too often or there is mold in the catching tray and tube. Best solution is to take a turkey baster (pump), disconnect the flexible tube from the tray, by pulling down, take a large cup with very hot water mixed with a spoon or 2 of Clorox, fill the baster with that mixture and pump it on the drain tube. You have to do it several times, water will come out, but do it until you hear a "woosh" sound and the water goes freely on the drain. Also spill some of that mixture in the tray so it kills the mold.
Posted on Apr 17, 2008
Anonymous
  • 8 Answers
SOURCE: water leaking from bottom of side by side refrigerator
The is a fairly easy way if you have a strong stomach.
On the back of the refrigerator, you will see a plastic drain line running to a pan underneath the box. This is the drain line for the evaporator condensate water. It is stopped up in the refrigerator section of the box.
Here is the tough part...Pull the hose out of the back until you can wipe it off with a clean towel and blow hard through the hose with your mouth.
By the way ...take your food out of the fridge...you will blow some pretty disgusting stuff out of the drain and into your desert if you don't. This will cure your leak.
Pssst...you can used compressed air if you are a wuss! lol
Good luck
Posted on Jun 10, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
halftank123
  • 102 Answers
SOURCE: Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Posted on Aug 05, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
ICE IS FORMONG ON THE BACK WALL OF A SIDE BY SIDE SUB ZERO REFIGERATOR.
This is typically a problem with the sealed system (refrigerant leak). Usually a circular patch of ice or water driplets half way down on the back wall. The solution involves replacing the evaporator coil. Subzero will give partial warranty up to 12 years.Full warranty for 5.A subzero authorized company is recomended.
Sep 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Sep 06, 2009 | Sub-Zero 561 / F
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
I have an older model subzero (refrigerator on top and a single drawer freezer on the bottom) which, when the bottom drawer is opened, leaks water. What to do?
Honestly I can't think of any cause for this that wouldn't require a qualified servicer. Most likey one of the drains is blocked and they make heaters to correct the issue
Jun 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero 685 water dispenser won't work
check the water resevour it is probebly frozen up arpound the outlet of it. its inside of the refrigferator, towards the back of the refrigerator down towards the bottom. take a hair drier and thaw it out.
Jan 16, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
528 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
