Question about Generac Electrical Supplies
I have a generac mod. 01646 don't know the age, 5550 rated watts, and in need of a muffler and fuel peacock with filter and grommets. Thanks for your help.
Posted by Richard Galan on
Generator Guru Parts
    Master:
  • 269 Answers
Hi!
We would be happy to help you identify the generator and get the parts for you. Just contact us on our website: https://www.generatorguru.com/need-help/
Our Generator Engineers are happy to assist you.
Regards,
The Generator Guru Team
www.GeneratorGuru.com
Posted on May 31, 2019
On a Generac Power House 5500 watt gerenerator, how would one reconnect the fuel filter/fuel cutoff to the fuel tank?
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link. Best Manuals
Sep 08, 2017 | Generac Electrical Supplies
Generac ix 2000 mod 0057932 start up ok but then stops running
Possibly blockage in fuel tank or line to carburetor? Fuel filter?
Fuel turn off valve? Generator malfunction that pulls the kill switch?
Owner's manual trouble shooting?
No manual try for owners and repair manual http://www.manualslib.com/
Mar 17, 2015 | Generac Electrical Supplies
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
I am trying to find the exhaust manifold or whatever the pipe is that comes out of the generator and connects to the muffler tube, I have a generac np50g, any ideas where i can find it?
WHEN THE ENGINE IS COLD put your hand on the muffler. Where the exhaust comes out is the rear of the muffler. Now go to the front of the muffler. The pipe that goes in is the one you are looking for. Keep following that pipe along until it joins the body of the motor, and you have found what you are looking for. Please rate this answer.
Sep 17, 2011 | Generac Guardian Ultra Source 15,000 Watt...
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Generac home generator does not start. It starts alittle bit but then dies. Maybe runs for 4-6 seconds
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
Feb 05, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Generac NP 50G Stops after 2-30min.
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Oct 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
138 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
