Model 011-1912-8 will not recharge. Everything is off, cable to electric outlet is new. What do i do ?
Posted by Brian Monaghan on
2 Related Answers
ryan frohlich
  • 78 Answers
SOURCE: Can the sony reader touch edition be recharged
i believe places such as futureshop or best buy do have outlet chargers for these. They only give you the computer plug in when you buy it, but they do have wall chargers for them all as well.
Just go to a store that sells them and they will have what you are looking for, or if you want try ebay
good luck:)
Posted on May 04, 2011
chucklednorr
Charles Norris
  • 74 Answers
SOURCE: new Haier 7.2V rechargeable NI-MH
Place the battery pack into your freezer overnight. In the morning charge it while still frozen. This fix will last about two years. I have been in the Laptop repair business for over 10 years. This is a common fix for laptop batteries.
Posted on May 14, 2016
I want to recharge a new phone.
Hello, Pamelia -
If your cell phone did not come with a charger (a cord with a connection to your cell phone and a male electrical plug on the other end to plug into a wall electrical outlet), then you will need to purchase one that will work with your model phone. You can purchase one from your cell phone provider or you may be able to find one at your local "big box" store.
You may also wish to purchase a cell phone charger which can be used in your car by connecting to the car "cigarette lighter" outlet and connecting to your phone on the other end. Just think how you would charge your phone without electricity.
You may also wish to find and purchase an "emergency" cell phone charger, for "just in case" situations.
Dec 31, 2017 | Cell Phones
New gps power up and shut off unespectually
GPS needs to be recharged . Recharge by plugging your GPS into an electrical outlet or into your car cigarette lighter while driving.
Aug 15, 2014 | Garmin GPS
Replacing a switch outlet combination with a switch GFCI outlet combination and there is only one cable in the box (14/3)
If it worked before, it should be a wire to wire replacement. You are replacing a regular switch/outlet with another switch/outlet which just happens to be a GFI outlet.
Wire the old switch wires to the new switch and the old outlet wires to the new outlet.
Cut the breaker/s off first !!
Sep 25, 2017 | Cooper Industries Electrical Supplies
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
Can the sony reader touch edition be recharged using an electrical outlet? If so, How? I purchased a converter device, but it did not recharge using the electrical outlet.
good luck:)
May 04, 2011 | Sony Reader Touch PRS-600
My Panasonic TV/DVD/VCR Combination has a dull buzz sound on all channels. How can I stop that Dull Buzz? Model number PV-DM2719. LBV
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 17, 2011 | Panasonic Televison & Video
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Cannot recharge camera
I didn't really solve the "problem". I plugged the charger into a different electrical outlet and PRESTO, the camera began to charge. The outlet I had been using, malfunctioned and had to be replaced.
Easy solution this time.
Nov 21, 2008 | Fuji FinePix 4500 Digital Camera
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Oct 02, 2008 | Televison & Video
Recharging battery
I have extra new, never used batteries\
Jeffrey @ [email protected]
Feb 09, 2008 | Homita USA HPU-701 Portable DVD Player...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
