Question about Pentax Cameras
Pentax e 40 changed batteries camera shows battery depleted
Posted by jonmacdonald on
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: Depleted Batteries
Clean the contacts in the battery chamber to get to the bottom of the chamber use an eraser on the end of a pencil Also the top contacts. you could also try packing out the contacts on the tops of the batteries to ensure good contact.
Posted on Sep 14, 2007
localwonder
Michael Masters
  • 6784 Answers
SOURCE: battteries depleted messageon Pentax Espio E40, even though have tried brand new batteries.
HI. this seems to be a battery scanning fault in the programming. try to reset the board by pulling the battery and removing all power of 30 minutes. completely drain all power from this unit for 30 minutes. if this message continues after you have rest the programming, this will confirm a serious fault within the internal program. you will have to send this device back to a pentax repair terminal for reprogramming.
Posted on May 22, 2009
Ty Price
  • 11967 Answers
SOURCE: Pentax camera showing battery depleted even with
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Oct 27, 2009
Anonymous
  • 2761 Answers
SOURCE: "Batteries Depleted"
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 02, 2009
Testimonial: "SORTED,THANKS"
Geoff Hone
  • 71 Answers
SOURCE: pentax k200d BATTERY PROBLEM
The battery charge indicator is temperature sensitive. If you switch off and on again, do you still get the low battery warning? Have you tried with a second set of batteries - either rechargeable, or lithium or alkaline. I would do this in a warm room, and try it with new alkaline cells. You lose some of the functions, but if the indicator say charged, and you can take a shot, then the body is OK.
Call me old-fashioned, but I use a multimeter on all NEW batteries to make sure they are functional - I bought a card of cheap LR44s and the first three were either dead or low on voltage.
Posted on Jan 05, 2010
Hi, i have exact the same problem that "cnscenery" with Pentax K200d. The camera has stopped working, only show depleted battery in the top lcd panel. I already try with many diferent batteries,...
This is a common problem with some Pentax cameras. The only solution that people have found is to turn the camera on and off until the battery indicator show a full battery. You can go to pentaxforum.com to read about others with the problem.
Aug 24, 2010 | Cameras
Batteries not registering
This is a common problem with this model...happens to me too. I find that turning it off and then on corrects it for awhile.
Mar 25, 2010 | Pentax *ist D Digital Camera
Camera optio e40 pentax shows the battery life as depleted even tho they are new batteries I have tried any new AA batteries 1.5 then I tried rechargagles at 1.2 for digital cameras.
this is not malfunction.
According to its manual, just turn it off ,wait for one minute and
turn it on again. It'll reset th camera. You need to reset the date/time.
Dec 25, 2009 | Pentax Optio E40 Digital Camera
I have a pentex optio m60 it was okey but suddenly it saying battery depleted could me please tell me what is the solution for that and why does it happen
There could be a couple reasons for this:
1. When you have the battery in the charger, does it indicate that the battery is dead or fully charged. I would suggest placing the battery in a universal charger to check to see what the rating is on the battery, a universal charger will indicate the true power left. If the universal charger shows the battery is drained but your charger says it's full, you have a bad charger. If they both indicate full but camera says dead, you have either a power supply issue in the camera or the main board cannot read how much life is actually left in the battery. If your charger says full and the universal says empty, your battery is malfunctioning.
2. Does the camera turn off when it says battery depleted or does it simply keep telling that it's depleted. If the unit doesn't shut off, you have a firmware issue that needs technical repair on. That specific model does not allow you to download updates via USB from your computer, you need to send it to Pentax for repair.
Dec 08, 2009 | Pentax Optio M60 Digital Camera
Pentax camera showing battery depleted even with new batteries,the camera just dies,even when new batteries are installed
Oct 22, 2009 | Pentax Optio M10 Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Dead?
Have exactly the same prob, my camera worked for 3 years without any probs, except that the alkaline batteries didn't have a long life...tried rechargeable batteries as well, but since three weeks ago it simply says, "batteries depleted", nothing works, tried everything...sending it to Pentax after the warranty is over is far more expensive than buying a new cam...really sorry for that, but don't think I gonna buy a new Pentax again...
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Depleted Batteries
Sep 14, 2007 | Pentax Optio S40 Digital Camera
Cameras Logo
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
