Question about Refrigerators
Where can I adjust thermostat on Danny fridge
Fridge is freezing everything
raise the thermostat setting to 4 ( 1 is near zero c)
if it still does it have the thermostat replaced
Nov 12, 2017 | Refrigerators
Hy i have a problem with my fridge freezer , the fridge compartment is acting like a freezer going up to -16
There is normally an adjustment knob inside the fridge, in the back or top to allow you to adjust the coldness. Numbered 1-9.
If you have already adjusted that it would help if I know the type (side by side, freezer on top or below) and the brand. Most side by sides blow some of the air from the freezer side into the fridge side with internal fans and vents. How is the freezer side coldness knob adjusted?
I would set both knobs to 5 and go get yourself a outdoor thermometer to put in each side. It should be about 35 in the fridge and about zero in the freezer. Remember it will be warmer in the top and colder in the bottom of each.
Was the thermostat you replaced in the freezer or fridge?
Feb 02, 2015 | Refrigerators
Adjusting the settings on a fridge thermostat
You've indicated that you have changed the thermostat but the model number you have given is electronically controlled via an NTC. If the the unit is built in there is a possibility that one of the following is causing the problem
a. the seal is no longer catching properly because the decor door needs adjusting.
b. the internal lamp is not switching off when door closes and is creating heat that the fridge is trying to compensate for
or
c. the fridge fan is not operating and not circulating the air to the sensor. (You can check the fan and light by pressing the switch at the top of the fridge compartment frame, the fan should run and the lamp go off when the button is pressed).
Try these first and repost if this does not help.
Feb 04, 2013 | Neff K9724X4GB
Calibration screw fridge
Try the thermostat on it's lowest setting first. If it doesn't switch off soon enough and gets too cold, you can get different thermostats from your supplier. A bottle fridge thermostat would suit.
Apr 21, 2012 | Whirlpool Refrigerators
The True brand commercial refrigerator at my job is entirely too cold. How do I adjust the temp? Beer is exploding!
You will need to adjust the thermostat.
The thermostat will be hidden at the bottom back of the fridge near the compressor.
You may need a screw a flat blade driver driver to adjust the themostat
Apr 01, 2011 | True TSSU-48-12 Refrigerator Commercial
Frosting up of the freezer. The fridge seems not to turn off
adjust the thermostat setting if digital type thermostat adjust it by pressing upward if your thermostat analog type rotate it counter clockwise then observe operation of thermostat. or replace thermostat maybe it is already damage.
Feb 12, 2011 | GE Refrigerators
Candy futura cfmf 266a fridge freezer problem
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
May 21, 2010 | Candy CPCA240FFK Bottom Freezer...
Fridge thermostat appears to have failed. Freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 20, 2009 | Refrigerators
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
The refrigerator doesn't make it cold enough to keep food fresh, even with adjusted level to 9
Jul 01, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
