How do i put a new password on my HuaweiB-525-5G-7E65 router. Thanks
Posted by magdie du plessis on
ray gallant
    Top Expert:
  • Computers & ... Master
  • 68,299 Answers
YOU CAN NOT CHANGE ROUTER PASSWORD .
Posted on May 22, 2019
How I put a password
How to recover my login Facebook password
Mar 09, 2015 | D-Link DIR-412 Mobile Broadband Wireless...
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Jun 24, 2012 | D-Link Computers & Internet
My new netbook won't accept my seven letter password on my linksys-G Home router. It's asking for 9 letter password which i don't have. please help
A linksys router password should contain at least 8 different characters. You have to put one or more character to change or put your password as authentication. If you have a further query then let me know. Thanks for using FixYa.
Sep 11, 2011 | Linksys Wireless-G Broadband Router
I put in the pass word a long time ago - have lost it - new lap top - how can I change the password ? so that I can use my new lap top on my wireless network
access the interface of the router and go on wireless there you will find the key that you have put on your router for wireless access..
Here is the step by step method ( connect a netwok cable to the router first ):
1. open your browser type in 192.168.2.1
2. Insert your username and password if it ask by default its username is admin and password:admin
3. Go on wireless
4. Click on Security
5. Copy the security key to your new laptop wireless and you should now be ready to access internet
If you need more help dont hesitate to ask me.. if it help you out please like the answer..thanks
Jun 01, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
DONT KNOW WHERE TO PUT THE CODE.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 16, 2011 | Computers & Internet
How to put password on my encore wifi router
Jan 05, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How do I get past or reset my key for the WRT160N? I put in what I thought was the key, but it doesnt accept it.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then Click on wireless-
Sep 23, 2010 | Linksys WRT160N Wireless Router
I forgot the password a i want to know how to reset the router so i can put a new password in
For reset router press RESET button for 10 seconds it is in back side of router.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP security change the password and save settings.Then restart router then you can connect wifi with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | D-Link GamerLounge DGL-4300 Router...
When i set up the router i gave a password but
If you want to change the password to access the router you can open your browser and put in the address 192.168.1.1 (unless you changed it) and press enter. You should be prompted for a user name and password. Leave the user name section blank and put in the password for the router. Once you have logged into the router successfully, you will see the Administration tab. Click on it and you will be able to change the router password. Save the changed and close the browser window when you are finished.
If you need to change the Wireless Internet password, you can click on the Wireless tab, go to Wireless security and change the passphrase there too.
I hope this helped. Thanks for using FixYa.com!!
Apr 18, 2010 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Computers & Internet Logo
19 people viewed this question
Ekse
Marvin
Marvin
