Question about Car Audio & Video
Bird that looks like an oriole but is red and black instead of orange and black
Posted by DEB EASTMEAD on
I was using my cleaner to get bird seed of the floor when it stopped working what do I need to get it working again please
Try pushing the reset button. Without knowing which floor cleaner you're using I can't tell you where it is, but mine is on the bottom. It's normally red or bright orange.
Jan 08, 2017 | Birds
Is a bird i found in myporch,big red legs black and have like a mohak.do you think i can find what family is belong/?
I am sure that you can find out what this bird is. Contact a conservation officer or nature guardian to get the info. I am not sure what the bird is.
Oct 07, 2014 | Birkenstock Florida Loafers
Bird identification by color
Is there a bird that is all red except for the white breast?
Jan 04, 2014 | Birds
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
