Question about Radio Communications
Scala rider g9 need to turn on to settings, announcements but it wont reconnise devise to change, my lites on devise but still wont reconnise device
Posted by David Birdsley on
2 Related Answers
NewCreationD
SOURCE: can Garmin nuvi 1390t be
I have the same problem - anybody have an answer?
Posted on Apr 20, 2011
mshe72
mshe72
SOURCE: the scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
The scala rider Q G A won't pair with my I Phone 4S it keeps saying nothing
Posted on Dec 01, 2012
Charge light on scala q3 does not go off when charging
I am more familiar with the G4 and G9 models but usually when the charging light will not go out the battery is beginning to fail. I believe I read that these models contain the same battery as the original classic Ipod. They can be found on ebay or Amazon.
I have batteries for the G4 and G9 models. I can be reached at Chris at RoamingDZ dot com. or 478-227-9445
Apr 12, 2014 | Cardo scala-rider Headset
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
Nov 15, 2013 | Cardo Scala Rider Teamset Pro
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
Oct 29, 2013 | Scala-Rider Cardo Scala Rider Q1 TeamSet...
I HAVE LOST THE INSTRUCTION MANUAL & WANT TO USE THE SCALA RIDER WITH MY garmin nuvi sat nav
Please find here a link to google search where the first 2 results are for the scala rider headset
http://www.google.com/search?q=scala rider user manual
Jun 20, 2011 | GPS
My scala rider battery won't hold a charge in standby - typically goes flat in about 8 hours. And I cannot get a reply about it from Cardo
Guys, if you roll out a device that can detect the battery if you own a soldering iron it can be easily replaced by a similar or even greater capacity.
Oct 12, 2009 | Cardo scala-rider Headset
My tom tom rider cnt find my cardo scala headset even tho it is on, can you solve, thanx
i have the tom tom rider 2 its a great bit of kit but i disconnected the scala cardo headset for helmets so that i cold try a different bluetooth headset for use in a car and it didnt work i then tryed to recconect it to my tom tom and it cant find it when searching for it what do i do ? what have i done?
Aug 06, 2009 | Tomtom RIDER GPS Devices
Volume
I had a similar problem when I first connected my Cardo Scala Rider set to the helmet. First off, make sure that the volume on the Zumo is set to 100% for BOTH guidance and mp3 functions. Then click the upper control on the Cado Scala to maximize the volume of the headset. When you've accomplished those two electronic hurdles, adjust the location of the speakers in the helmet - if location of the speakers is not optimized nothing you do with the electronics will have much effect. I typically run the mp3 volume at 20% and the GPS at 50% with the headset volume at halfway. My Cardo Scala unit is a Teamset and I sometimes have problems hearing my rider scream that I'm going too fast. I haven't bothered yet to tell her to keep the microphone closer to her lips.
Aug 07, 2008 | Garmin zumo 550 GPS Receiver
Radio Communications Logo
116 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
