Hi and welcome to FixYa,
Initially, a couple of checks:
Please postback results of initial checks.
Good luck and thank you for asking FixYa.
Appreciate your postback and additional informaton.
Most of the 'old' TVs would only work with 640 X 480 @ 60Hz, could the Toshiba be set that low?. You could also try replacing the yellow cable.
Try plugging the USB to another USB port of the Toshiba.
800 X 600 might still be hight then. What is the brand & model number of the TV pls? Â Additionally, pls confirm that the Kworld PC/TV converter is an SA235.
Sorry, pls is please.
A review if we may:video cable from yellow jack of Kworld PC/TV converter (marked AV OUTPUT) to yellow jack of Sony KV-36FS100. If at the rear, it should be either 1 or 3 marked VIDEO (not 4 marked Y); or
video cable from yellow jack of Kworld PC/TV converter (marked AV OUTPUT) to front yellow jack of Sony KV-36FS100 marked VIDEO 2 INPUT VIDEO;
press on the TV/VIDEO button of the Sony's remote a couple of times to cycle through the available video inputs till the laptop's display is shown;
on the Toshiba Fn + F5 a couple of times to cycle through LCD, TV, LCD + TV.
It would appear that all the conections and the TV's setting at Video2 are all correct.
A possibility is to try and exercise the P/N switches of the Kworld PC/TV converter.
How is the Kworld PC/TV converter  connected to the Toshiba please?
Could you try using the component video (red/green/blue cable) and set the Sony to Video 4?
Please confirm the exact model number of the Kworld PC/TV converter. The different models and products of KWorld maybe viewed starting here.
A possibility to consider is that the new Kworld PC/TV converter is not functioning as expected and would require replacement.
settings were checked and removed all cables except yellow composite. still large vertical color lines on tv screen. tried fcn/f5 and laptop screen does not show on tv screen
i replaced the yellow cable and checked the resolution 600x800 pixels. no change
The TV is Sony FD Trinitron WEGA KV-36FS100. The only information about the converter is KW-PCTV NTSC V1.4 No other information on box or packing list. What is pls?
Recheck- yellow cable from yellow video out jack on converter goes to yellow video 2 jack on the face of the TV
cycled through video1,2,3,4 only video 2 displays the vertical color lines
cycled through FN/F5
When I excercise the converter P/N switches, the TV flickers until I return to NTSC.
The Toshiba is connected to the converter through a supplied VGA cord.
The red/green/blue cable was connected from the converter to the back of the TV. The slider switch on the side of the converter was moved to the center position RGB. The TV video button was advanced through video 1-4. The TV screen on video 4 had color formed like "Zs". FCN/F5 buttons were used advancing through the icons.
