Question about Car Audio & Video
The red light syays on no green light - Car Audio & Video
Posted by Linzi Barrett... on
Just replaced speed sensor in differential on 2007 dodge dakota but brake and abs light syay on is there a way of ressetting this
make sure you pushed that senor all the way in. if its too far from the tone ring then itll keep the light on. also you have to drive it over 5mph to turn the light off after fixing it.
Aug 18, 2013 | 1999 Dodge Dakota
Need factory wiring codes for a 1999 jeep grand cherokee
battery red/white
accessory white/red
ground black
LF - light green/green
LF + light green/red
RF- light blue/ black
RF+ light blue/red
RR- tan/dark green
RR+ white/violet
LR- white/dark green
LR+ dark green/white
Dimmer orange
This wiring is for the standard audio system
Sep 17, 2010 | Car Audio & Video
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
When i try to put sons on my ipod they show up on my computer screen so that it looks like there are songs on it but when i disconnect my ipod shuffle the songs dont play and a light flashes green red...
Are you sure its green red green red or is it green orange green orange?
Because according to apple, it doesnt have a sequence for green red green red..... either way, you can see what the different lights mean here..
http://support.apple.com/kb/HT1407?viewlocale=en_US
Thank you and please be sure to rate this answer... :)
Sep 24, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
My cm2130 battery doesn't charge in my compaq presario 700 laptop
red light = 25%
Red + Green = 50%
Red + Green + Green = 75%
Red + Green + Green + Green = 100%
Mar 17, 2009 | Compaq Computers & Internet
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
