Sont STR-DE995 sounds blown out on vinyl channel. CDs sound great, phono sounds loud and bassy. Tested stylus and stylus looks good. Not sure if cartridge or phono channel? It smelled smokey recently
CD channel sounds fine, phono channel sounds extremely blown out and loud. It isn't stylus. Thank you
Posted by John Devlin on
Les Rogers
    New Friend:
  • 3 Answers
If you're up to it, remove the top cover of the case and look for any signs of burning or overheating (unplug first). It sounds very much like the Phono Preamp has gone.
Posted on May 23, 2019
5 Related Answers
b_hiphop2000
SOURCE: Playing regular cds with serato
cdj
Posted on Dec 02, 2008
Anonymous
SOURCE: Vestax Handy Trax
Since the Handy Trax Comes with a Sapphire needle, upgrading to a diamong one will give a better sound http://www.turntablelab.com/dj_equipment/1/131/4962.html
Posted on Jan 04, 2009
Anonymous
SOURCE: muffled sound from speakers when connected to laptop via amplifier
You need to buy an analog to digital converter box if you want to get superb sound quality from your computer.
Posted on Mar 10, 2009
Anonymous
  • 47 Answers
SOURCE: Kenwood A-97 Sound gone poor
It sounds like the amplifier is going. I remember when I accidentaly crossed wires, the amp did the same thing, then one day it shut off. It wasn't the same amp, but it doesn't matter, it sounds like the amp is on its way out. :/
If you still have the warranty, I would have them take a look.
Posted on Jun 17, 2009
Anonymous
  • 30 Answers
SOURCE: crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Posted on Jun 27, 2009
Stanton str-150 - poor sound from left deck
Just make sure all your connections are clean , your tt in horizontal and take a new record, set the azimututh/anti-skate right , use the channel of the deck which works correct if it doesn't you have to measure the voltage coming from the cable, since i don't believe it's the mixer. But pls describe a poor sound, that doesn't say a lot. My tables often make a poor crappy sound , with channels falling out, but that's due to dust on the vinyl and stylus(needle) or a poor connection with my sme connector and then i clean both. Does is crackle and move the rca cable when you're playing, often is that stuck , but if it's on both channels , which sometimes is hard to hear in a little room. It can't be the mixer, cause i told you to test it on the other, good soudinding mixer input. So then it can be your groundwire, There ain't much more. Good tonar, clean sme connector, clean record(take the needle from the right working table). Check if the pins in the sme connector move smoothly.
Goodluck
Jul 21, 2014 | Audio Players & Recorders
Loud buzz on both channels with new turntable and phono
The ground wire needs to be attached. The hum is a result of a bad ground.
Jul 12, 2014 | Audio Players & Recorders
I am getting extremely faint sound from the left channel while playing vinyl. I have swapped all wires and cables left to right and back and the problem remains the same. The only thing I haven't tried is...
If you switch the cables so the left channel plays into the right of the amp and the sound stays dead in the left channel of the amp it's not the cartridge that is at fault by your amp. Amps have a magnetic cartridge pre-amp built into them for turntables. This can go faulty, but won't effect any other device (CD etc). Most of these pre-amps are a single IC. Which will need to be replaced.
Oct 18, 2013 | Technics SL-1210M5G Turntable
Center speaker not working in home theater system
connect it to another computer to be sure is working fine. Then try to see settings maybe from manufacters utility or chek you sound card if suports more than 2 speakers
Apr 14, 2013 | Sony Str Da333es 5.1 Channel 400 Watt...
My new behringer vmx 200 dj mixer dosnt play sound from ch1 ...ch2 works fine ive tried everything but ch1 dont work
be sure when you select the chennel 1 input as your audio source you have an audio device plug inn at the channel 1 audio input..
Sep 11, 2011 | Audio Players & Recorders
Connected new polks to cambridge audio amp a1 (about 30 watts per channel) and play cds through a panasonic dvd/cd player, but i can't turn up volume past 1 without it sounding too loud. sound is ok, but...
Plug the player in somewhere else besides the PHONO input.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it because old-school turntables require it to preamplify the tiny current produced by a Phono cartridge.
I imagine if you REALLY listened hard to the result you have you would find the bass is WAY too.
Google 'RIAA curve' to understand why.
http://www.graniteaudio.com/phono/page5.html
Mar 28, 2011 | Audio Players & Recorders
When setting up a sound card to my m4 numark 3 channel mixer do i have the switch to phono or line
"PHONO" is ONLY for an old school turntable that would require a PHONO preamp, so that leaves, uh, LINE.
It's more than a matter of gain as Phono cartridges require special equalization to restore flatness to the sound recorded in a vinyl groove.
Mar 17, 2011 | Nu Mark Numark Dm3050 3-Channel DJ Mixer...
I have a Sony STR-DE995 receiver and surround speakers set up. However, most music material is not multi-channel. Is it possible to configure the unit so the rear speakers get the normal L-R stereo. I...
Stereo source material can actually sound pretty interesting when various DSP surround modes are applied to them.
Or you could seek out some multichannel music. Look on eBay for Super Audio CD's, DTS-CD's, Dual-Disc or DVD-Audio. Though these formats died on the retail battlefield they still can be found and will demonstrate some awesome capabilities of your receiver. I have about 100 of them.
May 25, 2010 | Sony STR-DE995 Receiver
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
