Question about Bose Audio Players & Recorders
SA3 amplifier. Why is LED blinking rapidly with no sound?
Posted by Fred on
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: Bose SA3
while hooking up the RCA'S? I wouldnt think so
Posted on Dec 12, 2007
Anonymous
SOURCE: Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Posted on Jul 16, 2009
palaboy
Rommel Cana
  • 5807 Answers
SOURCE: philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Posted on Sep 10, 2012
joyrexjj
Joy Rex
SOURCE: Problem with amplifier Technics SU-V500
technics amplifier su-d5000 user manual
Posted on Dec 30, 2013
bairsjw
Josh Bairstow
  • 15 Answers
SOURCE: SA3 amplifier to move to Europe : capability of the transformer ?
the transformer in the SA amps will need to be changed or you will need a voltage converter
Posted on Mar 11, 2014
Where is the fuse on a bose sa3 amp?
It will be on the inside of the amp, located on the power supply board. The are many types of fuses, so it may may not like like you expect.
May 19, 2014 | Bose Lifestyle SA-3 2-Channel Amplifier
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
Bose sa3 amp, blew a fuse in it, replaced it and now it won't power up. Nice little amp, would like to find out how to test out what is wrong and fix it
If you can,check with your multimeter to see if the two voltage rectifiers are good.If they are OK,you may need to replace the 2 audio amplifiers.This will require proper tools and good experience.
Jan 06, 2013 | Bose SA3
How do I connect 2 jbl ct 26 speakers in a series to Bose sa3
I don't know the impedance of these speakers but the Bose SA3 amplifier is 100watts per channel.A higher wattage speaker may damage the audio amplifiers.
Aug 28, 2012 | Bose SA3
While living in the States I purchased a Bose Acoustimass 10 system but have now moved back to the UAE. As the system operates on 115 volts ONLY I would like to get it work on 240V without having to use a step-down transformer. By changing out the transformer form 115v to 240v will it work or will I have to change any other components within the system. Can anyone help me??
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose SA3
Dec 12, 2007 | Audio Players & Recorders
97 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
