Sears didn't post a manual for it.
There are parts diagrams at the link below:
https://www.partswarehouse.com/Ryobi-TS-251U-Miter-Saw-s/344743.htm
SOURCE: cannot find parts for ryobi 15in miter saw
Go to this site for parts. You will need model number though.
http://ryobitools.arinet.com/scripts/EmpartISAPI.dll?MF
SOURCE: Lost User Manual for Ryobi Miter Saw. Where can I get directions
Go to RyobiTools.com and click on products or in the upper right hand corner type in your model number and you can download a manual and also parts breakdown for this tool. Dave
SOURCE: I have a 10 inch ryobi miter saw, ts251u, the
Bad news, the swich you need is part number 350001 and it is no longer available. Might I suggest that if you have a local repair center take the switch and see if they can match it up with another mfr. switch. Some of the Milwaukee mitre have switches like you describe. Sorry I couldn't give you the answer you needed.
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
SOURCE: I do not know how to release the blade so it will
When you are facing the saw look on the right hand side in the area where the arm pivots. There will be a silver shaft with a groove just in front and slightly lower than the pivot. If you hold down slightly on the handle and pull out on this shaft it will allow the arm to lift up. Locking the arm down is reverse.
Here is a link to the owners manual for this tool.
http://www.ryobitools.com/product_manual/file_url/378/TS1342L_329_eng.pdf
