How do I get it open
SOURCE: my 94 850 sedan's glove compartment will not open.
turn the handle and push down on the glove compartment. it will unlock and open up if you apply enough pressure
SOURCE: cannot open glove compartment handle broke
If you raise the handle and look under it,you will see a metal loop sticking out,If you grab that with a pair of needle nose pliers Or other small pointed object and pull,It will open.
SOURCE: Glove Compartment Box Won't Close
Check out this link. Explanation for the fix. http://forums.vwvortex.com/zerothread?id=2359362
SOURCE: Glove compartment stuck
I just opened my friend's stuck Toyota Corolla glove compartment by
pushing in on the bottom right front with my foot while pulling the latch and giggling it. The latch turned out to be broken. Good luck.
SOURCE: broken handle to glove box in my Galant
This happened in my '01 galant as well. If you take a peek under where the handle used to be, there's a little square nook with a spring and a little plastic tab. take a key and stick it right above the tab and press down, and the glove compartment should just pop right open. If it doesn't work, then it's probably just locked. Just unlock the door and try it again.
