Question about GPX Audio Players & Recorders
GPX cd music system model HM3817DT CD's will not play. I can see the cd spinning.
Posted by Johnny Wesson on
5 Related Answers
Anonymous
  • 417 Answers
SOURCE: cd player
ITS THE LASER TRY CLEANING IT IF THAT DONT WORK IT NEED REPLACING
Posted on Jul 03, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: New GPX Home Music System - no sound
Unfortunately, GPX has, in my experience, a poor reputation for quality. I wouldn't delay either exchanging it or filing a warranty claim once you are sure you have done your homework and have things set up correctly.
Posted on Oct 28, 2008
Anonymous
  • 9 Answers
SOURCE: Durabrand model HM3817DT radio/CD player- cd eject,radio volume
Durabrand products are prone to alot of problems!!! In other mords they really ****!!!
Posted on Aug 25, 2009
Anonymous
  • 4 Answers
SOURCE: The remote for a GPX Model HM3817dt was chewed by
Check the back of the manual. It has a directory of where you can e-mail or call the company for parts.
Posted on Oct 10, 2009
Anonymous
  • 10 Answers
SOURCE: cd does not play
Does the radio work? If not, make sure the volume is up. If so, the speakers are not blown. Return your product.
Posted on Oct 15, 2009
Need Manual for GPX model 8544
some wont play copies mine wont
Apr 13, 2015 | Televison & Video
HM3817DT
I think you have a GPX Music system HM3817DT.
Try this site to dowload a user manual that helps with instructions for the remote control.
http://www.gpx.com/owners_manuals/HM3817DT-IB.pdf
Aug 04, 2014 | GPX Audio Players & Recorders
Gpx stereo cd won't work
The laser pickup head has failed, or the pladder motor that spins the disc is open, or there is no voltage to the motor. Chances are the whole assembly will need to be replaced, but as a rule it is cheaper to replace the stereo.
Jun 23, 2012 | GPX HM3817DT Shelf System
Need manual
The manual for the GPX HM3817DT is available from GPX. Start at http://www.gpx.com/store/pg/78-GPX-Support.aspx and click on your model. Then click on the Downloads tab. The direct link to the user manual is http://www.gpx.com/owners_manuals/HM3817DT-IB.pdf .
I hope this helps.
Oct 17, 2011 | GPX HM3817DT Shelf System
The cd player will not rotate the cd that is in the machine. Its in cd function.
Hello
Check whether the CD loads into the mechanism fully inside. If it does not spins even after loaded well into the mechanism, the sled motor of the loader mechanism to your devie is faulty, and should be replaced. OK.
Aug 21, 2011 | GPX HM3817DT Shelf System
Can't load a cd...just out of the box
If you cant load a CD then it either doesnt belong in that CD player or your CD is to scratched up to play.
Dec 31, 2009 | GPX HM3817DT Shelf System
CD pops off
Despite the lack of set-up instructions with this product, I finally figured out I had to remove the cardboard disc covering the guts of the machine.
Dec 14, 2009 | GPX Audio Players & Recorders
I ripped a CD on my computer than tried to play it on the GPX it wouldn't play but the screen said "File". What does that mean and can I get it to play a ripped CD?
You have to burn a CD in "CD/Music" format. You can't burn it as a data CD. Which just sucks cuz doing it in CD format, you can only fit 15 or so songs on each CD. And I wasted a CD finding that out.
Aug 31, 2009 | GPX HM3817DT Shelf System
HM3817dt
You will not believe it, but he solution if Homer D'OH! simple. Had the same thing, until I realized that what I thought was the CD hold spindle is acually a cardboard protector for the CD components. It seems to be a very flexible CD player "face" correct? It's actually removable cardboard - pull it out and the CD components are now exposed. The CD will properly mount on the spindle...has pretty good sound.
Feb 19, 2009 | GPX HM3817DT Shelf System
Top GPX Audio Players & Recorders Experts
Jean Sintulaire
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
