Question about Kitchen Appliances - Others
Miro runs but no heat. overheated making popcorn, set for 2.15 min, smoked.
Posted by Bert Eliasson on
Dennis
    Top Expert:
  • 1,052 Answers
Probably fried the magnetron. If the MW has no water to absorb the radiation, the energy will be returned to the magnetron and overheat it.
Sears will service most brands but expect to pay around $300+. If countertop unit usually cheaper to just buy new.
Posted on Jun 03, 2019
Ivan Patrik
    New Friend:
    Problem Solver:
  • 11 Answers
Check / replace thermostat
4 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: it runs, but does not heat anything.
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediodeand capacitors can br tested. The capacitor must bealloweddischargebefore testing, or you risk to get electrocuted, evenifpower is off.Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
A Miller
  • 8404 Answers
SOURCE: OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Posted on Sep 21, 2009
Anonymous
SOURCE: 2003 Protege 5 overheating on long runs.
I just replaced the radiator and thermostat on my 03. The radiator was defective (corroded) on the lip where the cap seals. This allowed coolant to be spat out. The thermostat was also sticking closed after new radiator and this caused overheating. Replace both while in there for under $100 if doing it yourself.
Posted on Mar 11, 2010
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave about 3 years old. Started making a bag
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal of the oven wall is burned or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth, then apply paint.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Posted on May 28, 2010
What is making a popping sound from my engine and making it smoke and sputter?
digging in the internet I found this:
too much fuel blows black smoke - brake fluid and auto trans fluid burns white - water makes steam - burning oil makes blue smoke you nead to work out witch one of you fluids are droping in level
hope it works :)
Mar 15, 2016 | 1995 Buick Regal
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
I cant find my instuction manual
Pre heat kettle 5 mins. Put in oil, popcorn, and popcorn salt. Dump kettle when done popping.
Use 3 parts popcorn to 1 part oil. Measurements are different for each model popper.
Dec 25, 2013 | Kitchen Appliances - Others
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
My Beaumark popcorn maker isn't working! I have the type that is a large domed electric pan, with a metal 'stick' that goes around to move the kernels (presumably to stop them from sticking?)....
your problem is in the instructions.. you need to make it a little hot, means run it on empty for a few min. stop the machine, and add 2 tablespoosn of veg. oil your fav. oil, not olive. add enough pop corn to fill the inner circle surface of the bottem plate, then run it again until the bowl is full.. maybe 5 min. You should have perfect bowl full of pop corn.
enjoy :-)
Sep 15, 2011 | Vacuums
Hi. I have a brand new Benchmark Premiere 6 11068 popcorn machine. Ever since the first time using the machine the kettle smokes up. It smokes the entire 5 minutes while heating up and continues to...
could be that the bowel had a thin plastic protection on it when new that should have been peeled off before starting it up
could be a wire touching the hot bowel and melting
what ever , it is under warranty so take it to a service dealer or authorized repair shop and have it checked out
smoke and smell are food contaminants so the cause has to be found for safety reasons
Apr 17, 2017 | Benchmark 11065 Popcorn Maker
We spilled melted butter into the base that holds the kernals. Now we get black smoke when we plug it in. I tried running it on empty for awhile, but the smoke continues. Can we remove the top and clean...
you can open it but not from the top. unscrew the bottom and take out the heater and clean out the Popper without using any water or soap just a toothbrush and cloth. it will take more then one clean out to get it to stop smoking (took me 3 times). put it back together place a plate under it to catch butter and run it for 10 min. to get hidden butter to melt and seep out of hidden spaces then repeat cleaning.
Sep 11, 2010 | Presto 04820 PopLite Popcorn Maker
a
Sep 21, 2009 | Microwave Ovens
Doesn't heat
The heating element has burnt out or is defective! return for repair or if you have recipt a new one!
Jan 25, 2009 | Cuisinart CPM-900 Popcorn Maker
Kitchen Appliances - Others Logo
122 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
