Question about Watches
Is GEORGE FMDGE#159 A Good watch - Watches
Posted by Jefftey costa on
Andrew Taylor
    Top Expert:
  • Watches Master
  • 33,114 Answers
Good enough to tell the time, but George is a Walmart brand isn't it?. The specs say it has a Japanese Quartz movement, so the same as Seiko. Therefore, it will keep good time.
https://www.amazon.com/George-Black-plated-Mens-Watch-FMDGE167/dp/B004RBCRQS/ref=cm_cr_arp_d_product_top?ie=UTF8#technicalSpecifications_feature_div
Posted on May 21, 2019
2 Related Answers
Anonymous
  • 3 Answers
SOURCE: battery is good, but watch stopped.
You need to hold in reset and mode to make it go back on.
Posted on Dec 31, 2009
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: what is the value of a George watch model FMDGE
mcdevito75 here, It would depend on who made the movement, From what I can gather the George Co. replicates watches of all kinds. Your George watch is a replica which can be very good depending on who made the movement. If you can"t remove the back cover and get the name off the movement, vist a small watch repair shop in your area, Remember your George watch could have a high end movement so be carefull. Replica watches have value, depends on which maker.
Posted on Jun 29, 2010
Is gegrge a good watch
Dear
The george watches, I like it.
Thanks.
Feb 27, 2015 | Watches
Would just like to know how much the george fmdge 158 is worth
The movement ob mine just says Japan no jewel unadjusted any idea on value?
Jul 29, 2011 | Watches
How to set day on non digital george watch
I'm not familiar with the George watch but analog (non-digital) watches typically have a stem with which you set the time and the day. On most watches the stem has two clicks when you pull it out (gently). The first clich should set the day by rotating the stem counter-clockwise while the second click sets the time. On wind-up watches this stem also winds the watch when not pulled out.
May 01, 2011 | Watches
HI I am ahving the above problem ie analog shows 09h00 am and digital shows 02h00 am? regards George Christelis
You can reset the hands so that they agree with the digial display.
I don't know which watch you have but my Casio requires me to press the "mode" until the display says "HS" and then use the buttons at 2 or 4 o'clock to advance or retart the hands.
I suspect that your watch is very similar and you should be able to find the method with a little experimenting.
Good luck
Apr 19, 2011 | Watches
What is the value of a George watch model FMDGE 184
Jun 28, 2010 | Watches
Watch Band requires replacement
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Watches
Battery is good, but watch stopped.
Dec 31, 2009 | Novelty Watches
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
Nov 21, 2009 | Watches
George watch
From the clock mode, hold the Lap/Rest button until the "seconds" counter flashes. Use the Start/Stop button to advance the time, use Mode to switch between hours, seconds, date, etc.
Sep 11, 2009 | Fossil Watches
Watches Logo
216 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
