Question about Baby Gear
I have a Legacy Kids Full Poster bed that the white outside rail has come out of the footboard connection. We have 1 Peg and are unable to figure out how to reattach it. Can you help direct us?
Posted by Laura Hartman on
5 Related Answers
Anonymous
SOURCE: conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
Posted on Jan 20, 2009
Anonymous
SOURCE: bed rails to convert to full size bed
We purchased our bed rails through Babies R Us. Be patient, they need to find the right part # through their catalog and this took a couple of days to find, but they finally did find it and we got our rails a couple of weeks later.
Posted on Jan 30, 2009
Anonymous
SOURCE: I need bed rails for the simplicity ellis crib.
i have the same problem but i searched long and hard and found this wesite where you can purchase the conversion rails.
Simplicity Ellis Crib Conversion kit for Full size Bed
http://www.nybabystore.com/p-4994-simplicity-ellis-convertible-kit.aspx
Posted on May 06, 2009
Anonymous
SOURCE: Jardine Black Olympia lifetime convertible crib
I called Jardine Enterprises and they said they would email me a manual . Call them at 1-800-295-1980 and provide them with the model number and mfg date of your crib and they will send you a manual via email.
Posted on May 20, 2009
Anonymous
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Posted on Jul 18, 2009
Assembly instructions for savannah loft bed
You could try Amazon, look in the question & Answer part.
Call: toll- free customer service number and have this assembly manual open to the parts list ready to provide the model name, and part name or number.
Customer Service 1-877-864-5752
I'm l
ooking for a replacement parts list and the numbers for each piece. Mostly the footboard in the expresso color. PLEASE help!
Jan 24, 2016 | Target Home Kids Bed: Savannah Loft...
Need manual for b119-54
https://www.homelivingfurniture.com/i147393/b119-54-ashley-furniture-enchanted-glade-kids-room-bed-full-trundle-footboard-with-rails there is an 800 number to call, that set is not made anymore.
Oct 09, 2015 | Cameras
I have the Ellis 4 in 1 and I am ready to make it a full bed, but I can not find the bed rails.
You can use about any full size bed rails you wish. They may need a little fitting but if you are looking for actual Ellis 4 in 1 bed rails here is a place that sells them http://www.babylox.com/simplicity/ellis-full-size-bed-rails-espresso225893.php Ellis no longer makes them rails themselves, they were discontinued.
Mar 22, 2011 | Toys
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
Bambino Reale 312C crib conversion to double bed
I have the directions- but it is poorly written by the company...
I could scan and email I guess - if you still need them.
Nov 06, 2009 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Converting crib to toddler bed
It should have come with the toddler rail when you purchased the crib.  Simply remove a few screws and take the front of the crib off (what would be the footboard).  Then simply slide the toddler rail in the tracks.
A purchase of adult rails is required to make the conversion to a full size bed for the next step.
What color is the crib?  Call at 770-974-8895 if we can help with your toddler rail.
Sep 10, 2009 | DaVinci Emily Crib
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
TRying to change into full size bed with no instructions do i need special rails or standard ones?
The fourth stage is where the bed can be turned into a full size bed. The "front side" and the "back side" are turned into the headboard and footboard. However, at this point a steel full-size bed frame would need to be bought (from any mattress store) to turn it into a full-size bed. You used to be able to get matching wood side rails from Simplicity but since they went out of business you can't. you could have them made if you found matching wood or stain from lowes. not that hard. that's what we did.
May 31, 2009 | Simplicity for Children Prescott 4-in-1...
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at [email protected]
Feb 21, 2009 | Baby Gear
Baby Gear Logo
143 people viewed this question
Top Baby Gear Experts
Marvin
Marvin
Paul Carew
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
