SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
SOURCE: My RCA model D52W20 will not fully power on when
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
SOURCE: TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
SOURCE: tv wont turn on
unplug the unit and leave over night. replug the TV in. in the morning to a known good outlet. if this don't work take it to a service center.
