Question about Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs
It just stopped working. I click the "on" button and nothing. The last time i used it, it was fine. No problem. 1 week later, i go to turn it on and nothing! Like it just decided to stop on me without any type of foreseen problem. Can anybody figure thar one out?
Posted by fwashingtonb on
Anonymous
    New Friend:
Had same problem (and also broken battery mount handle - second time). Micro switch checked good (ohmmeter). Battery charger said good (confirmed with voltmeter). Problem was simply corrosion build up on contacts. Fine grit sandpaper and steel wool fixed it. Now have to find replacement handle halves, like I did before. Easy to see why they changed design.
Posted on May 15, 2010
Anonymous
    New Friend:
The MicroSwitch inside the handle is stuck or has gone bad. Part is under 5$ but where to find it is a different issued. Good luck
Posted on May 01, 2010
Three weeks ago my refrigerator went out including the freezer. We pulled it out, used our wet/vac and cleaned it out then turned the reset button and it worked fine. A week later it went out again and we...
im not sure what reset button you are using / but cleaning it out was good . and if it started running that was good. when it quit the third time . things that would cause this could be the cold control / very common / and at 15 yr old i would replace the compressor relay . that starts it . sometime you can hear it clicking or humming . ( trying to start . . so try the relay .. . and ck for bad connections on old wires to the compressor as the get brittle and burn off .. mm hope this helps .. feed back .. pls
Jan 19, 2011 | Amana Refrigerators
1993 ford crown victoria lx new battery, car stopped, won't turn on???
Sounds like you have a bad heater core. If steam is on the interior you may want to look for moisture around the floor at the firewall.
Aug 03, 2008 | 1993 Ford Crown Victoria
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
Philips HDTV does not turn on
I would check the line coil and horizontal and low voltage regulator transistors.
Jan 21, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Total power failure
same here! first my original car charger stopped working, so i purchased a replacement (a generic one off ebay), plugged it in and the little light on the top right turns on. but i have not been able to turn it on. i've left it charging for at least a half hour and nothing. any ideas?
Nov 24, 2007 | Magellan RoadMate 3000T GPS Receiver
Clarion DXZ655MP Speakers worked then stopped...
sounds like the ohm load of your speakers is incorrect and overloaded the amp,....check all your specs, i.e. max, min ohm load on stereo, and speakers,...this stuff is important and must be within the range allowed or stuff like your experiencing happens,.....it's happened to me before,.....fried my amp because i had house speakers in my van, was great for about 3 loud days,....good luck, cracklin joe,.......
Sep 26, 2007 | Clarion DXZ655MP CD Player
Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
414 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Marvin
Marvin
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
