Heating & Cooling Logo
C
Cheong CY Posted on May 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Electrolux EWF1090 PCB burn.There is one Transformer with Printed "Hartu 717162-51" burn. May i have detail of this transformer ? Primary Side voltage (2 pins) ? Secondary Voltage (3 Pins) ? VA ?
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on May 21, 2019
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
499863
Points
3432
I would investigate what voltage the transformer connects to for primary and what voltage devices connect to secondary. Bring in a temporary power source and read the amperes it draws to operate and find the product of secondary volts and amps to select a new replacement txr
5 Related Answers
A
Anonymous
  • Posted on Nov 28, 2007
SOURCE: JCR-160 clock radio Clock running slow
The clock works off the frequency (hertz). In US the electrical wave frequency is 60HZ/sec and in India and many other countries 50HZ/sec. Hence, the clock slows down about 6 seconds or so every minute.
Anonymous
  • 4 Answers
  • Posted on Mar 07, 2008
SOURCE: Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Oct 01, 2008
SOURCE: Kenwood RXD 501
Do you already check the thermal fuse on the primary side of the transformer
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Oct 04, 2008
SOURCE: HV Transformer and Maganatron
I would not recommend an inexperienced measuring secondary voltage on the high voltage transformer! The filament winding produces about 3VAC but the high voltage winding produces well over 2000VAC! And that can be instantly lethal!
I would only recommend measuring the resistance (in ohms) of the windings with power off and capacitor discharged.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
The part number listed by the distributor for the high voltage transformer is RTRN-A527WRE0 (zero on the end, not "oh") which is the same number shown in the service manual.
The two continuity checks on a magnetron are across the filament terminals, which should read about zero ohms, and from each terminal to the case, which should read open or infinity.
Even if a magnetron passes these continuity tests, it can still be bad.
Anonymous
  • 21 Answers
  • Posted on Nov 19, 2009
SOURCE: HP printer AC power adaptor 0950-4399
I just get one from www.order-bulk.com my print is working now
How do I fix an ikea lamp with a burned out transformer.
go to an electrical whole sale business and see if there are transformers available that meet the specifications on the side of the original units and if so then consider getting them and have an accredited electrician change the plugs / sockets for transformers to burn out I suspect that the input voltage into the transformer is not as specified on the trans former and any transformers that you get will have to have the same primary voltage as wht is available at you place
2answers
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 • Ovens
1helpful
How to identify the matching transformer terminal by means of terminal resistance? and which terminals is for input or output?
Doing a resistance test on a transformer will not give the information you require as you will read very little, if any resistance. What you need to do is an impedance check and that gets involved. If it is a normally wound transformer, not an auto transformer, you can isolate which is the primary and the secondary windings. Unless the transformer is a multi voltage input unit, the primary side will have continuity through only two terminals. The secondary could be more than two if it is a multi output voltage one. If the transformer is a step down, the primary windings will be the thinner wired windings and vice-versa. To actually test the transformer, get hold of a transformer with about a 20 vac output and try it across the two terminals you have identified as the primary windings, you should ge a proportional voltage of the actual output. eg. with 20 vac input and a 2 vac reading at the secondary, the actual output would be 11 vac if your mains voltage is 110 volts. Take care that you are using the transformer at the voltage it is designed for, otherwise it will overheat and burn out.
3helpful
Model ewf1090 electrolux.displays E90 and flashing green lights
its an electrolux fault code.that means .bad connection on communications wire.this is a blue loom of about 5 wires that come off the main pcb and connect to the display board in fascia panel. clean pcb terminals and tighten loom connection pins and this should solve problem"
wd 40 or another type spray should do it........
cheers
There's no high voltage ,thus no magnetron activity
check the ceramic fuse in the primary circuitry as it probably blew out when the primary connection arced and burned through
It wont turn on
If nothing will come on check the breaker to the indoor section, check that the service switch by the in door section is on and the blower door cover is tightly closed. If all these junctions are transmitting power then it may be a burned out transformer. If you can check for 120v on the primary coil of the transformer and 24v on the secondary that would tell you where the problem is. If theres no voltage on either side then backtrack from the transformer on the 120v side till you find 120v. If theres 120v but no 24v your transformer secondary is burned out. If theres both then the problem is downstream from the transformer: circuit board 3amp fuse, loose wiring.
2answers
NATIONAL NNN -C 2000P LOW VOLTAGE PRIMARY GETS FREQUENTLY OPENED
There is something on the secondary side which is drawing too much current. I would check all electrolytic capacitors, zener diodes, transistors, and voltage regulators.
Top Electrolux Heating & Cooling Experts
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
