Question about Radio Communications
2019 honda goldwing cb radio does not transmit - TX light comes on - CB radio does receive transmissions from other cb radios
Communication system is a Sena 20S EVO that is connected to the motorcycle via Bluetooth. Can hear others transmitting. When pressing the PTT switch the TX light comes on - everything is quite and others cannot hear me transmitting.
Posted by Greg Gordey on
sadiq muhammad
    Champion:
  • Radio Commun... Expert
  • 228 Answers
You check your radio with other radio very near. If radio is hearing your transmission then it mean that your Radio Power Module not working if very near radio not listening you then your preamplifier and Power amplifier is not working, it mean your Radio Transmitter faulty, only Receiver is working, you consult with any Radio Service shop. One other thing if you have software also check Tx/Rx frequency it must be same for simplex operation.
Posted on May 21, 2019
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: my galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
Goober Pyle
  • 14 Answers
SOURCE: Have Cobra 29 LTD CB
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Posted on Dec 22, 2008
Anonymous
  • 3 Answers
SOURCE: CB Radio on 2003 Honda Goldwing quits working
i would ck all plug in wires under seat if there ok ckplug in wire under right side lock glove box
Posted on Jan 28, 2009
Anonymous
  • 55 Answers
SOURCE: CB Radio will receive but not transmit
Sound Like The Modulation Amp May Be Dead..
Or a Componet in The Mod. Section....You Can Pick up The Repair [email protected] www.samswebsite.com For about $20.00...Good Luck
Posted on Feb 21, 2009
Anonymous
SOURCE: No audio Transmit
Try a hand mic with the set, there may be a short within the radio.If not your problem is with the audio amp in the radio itself.Repair should be about $15.00.
Posted on Aug 09, 2009
Why does my new Honda CB always show RX receiving transmission no matter where squelch is set?
if this is on a Goldwing, it appears that you have a shorted pin int he connector. Disconnect the radio and make sure all of the pins are straight and connecting properly.
Oct 02, 2014 | Radio Communications
Tx red light on cb base light is out what will this effect
The red light on usually is on only when the mic is depressed showing you are live.
Jul 21, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
2001 Honda GL 1800 Gold Wing CB radio not receiving clearly
Hi, David for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
GL 1800 CB radio problem
CB radio not receiving any more GL1800
Honda GL1800 Service Manual
GL 1800 CB RADIO operators manuel GL1800 Information Questions...
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1800 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 11, 2013 | 2001 Honda GL 1800 Gold Wing
I have a 2006 Goldwing with a Auto Com bike to bike communication system on it. It is tied into the OEM bike system. The bike did not have a CB on it so I installed one last year, but the problem that I...
Hi Walter,
When you're out riding with your mates, how close to the person you are trying to talk to is from you on the road?
If you are within 2 metres of the person you are trying to contact, neither they nor you will hear each other, keep at least 5 or more metres from each other and you should be able to chat with each other, remember that radio waves need room to move in before they are receiveable.
These units are low powered, that is to say no more than 1 watt rf output power, so the most distance that these radios can transmit to is about 5 kilometres line of sight only.
I hope this helps
Regards,
Peter
Feb 23, 2013 | Radio Communications
How to remove a 1990 Honda Goldwing GL 1500 factory CB radio?
Hi, George for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GL1500 CB Radio Removal GL1500 Information Questions goldwingdocs com
GL1500 CB radio install Help
Template service manual $5 donation very cheap
Honda Goldwing GL1500 SE Owner Manual
Apr 06, 2017 | 1990 Honda GL 1500 SE Gold Wing
My cb will receive but i can't xmitt. am i on the proper channel and band width? can anyone help
1' its a mobile rig. 2' dose the red light come on when you transmit?
try switching to FM, to do checks. watch the metre rise during tx.
Aug 03, 2011 | Connex 3300 240-Channels Base CB Radio
Key to tx-green lite out-no output power or red lite rec ok
It could be small transistors--in the back where the light and transmit hook up. One small transistor will shut down transmit & possibly receive. Get it serviced at a radio repair shop. if you know how do it yourself. Change all small transistors to 2sc3904 or 2sc 3906 at "Radio Shack."
Apr 30, 2011 | Cobra 29 LTD CB Radio
2002 Honda GL 1800 Gold Wing CB radio receives but won't transmit
Hi, Ohenry428 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
New CB Radio in 02 GL1800 Won Transmit
cb radio no transmit GL1800 Information Questions goldwingdocs com
https://www.partsfish.com/page/oem-parts-for-honda
http://goldwingchrome.com/Manuals/GL1800/Honda%20Goldwing%20GL1800%202003%20Owners%20Manual.pdf
Jun 20, 2010 | 2002 Honda GL 1800 Gold Wing
My galaxy 959 cb radio wil not put out any transmit
6. too high SWR.
Feb 16, 2008 | Radio Communications
Radio Communications Logo
192 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
