Question about Kenmore Dryers
Kenmore QuietPak9 Smart Heat stopped the middle of drying. Sensor says sensing dampness and sensor that says check lint screen keeps coming on. So now the dryer will not turn on. What is wrong?
Posted by jr Heger on
5 Related Answers
JR JR
Johnny Ramirez
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
James Chandler
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
Mike Inman
  • 219 Answers
SOURCE: Dryer switches from sensor dry to 17 min, on time dry it just doesn't heat up
check your ignitor id make sure the vents cleaned as well
Posted on Jun 03, 2009
Anonymous
  • 212 Answers
SOURCE: dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Posted on Jun 24, 2009
Controlfrk
Controlfrk
  • 304 Answers
SOURCE: drying not drying, clothes moist after hours
This is likely the result of an air flow problem if you are sure the heater is working. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Posted on Sep 19, 2009
Where are the 2 metal smart sensor drying strips on the kenmore smart heat quietpac 9
Usually on inside of dryer drum on backside of lint filter housing.
Jul 27, 2017 | Kenmore Dryers
No error code but if you push setting it and check lint screen flashes. I have checked lint screen all the way to vent outside. I can feel cool air from outside comming through lint screen so im sure it is...
That Kenmore dryer is a hybrid of a LG dryer that check filter lite is only a reminder for the customer to check their lint screen every load... You can call customer service at sears to confirm this. I have may customers call me and say it wasn't there before, I goto there house call customer service in the home, hand them the phone and collect a service call about 5 times a month. If every thing is drying well, just leave it alone.
Mar 26, 2015 | Dryers
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Softtronic t8303 the machine stops when drying clothes after about 1 minute and the alarm goes off until the machine is shut down. When i try to start the machine with no clothes in, it keeps going till...
One possibility could be that you have a clogged LINT DUCT VENT to the outside.
It sounds like the damp sensor is working fine as when your unit senses no moisture, it shuts off. Soooooo, if the LINT DUCT VENT is partially clogged somewhere between the dryer tub and the outside of the house, then the sensor is sensing too much heat because the air flow is limited terribly somewhere. Take your entire LINT DUCT TUBING and clean it completely. Also, make sure you do not have any loops or droops in the whole ducting route. Make sure the lint duct tubing is not having to blow uphill anywhere in its route to the outside of the house. Dryers can not blow damp lint up hill very well and when folks try to make a dryer do this, the dryer will try, but damp lint will collect in a low spot, or in a hose route that has too many turns in it to the outside. Make the route of the hose LEVEL and even downward if possible. If it is a good idea to vent the hose out the side of the dryer, (to reduce turns, - remember they are death in a dryer) if possilbe. Not all dryers allow this. Look in your users manual for any suggestions.
kindly,
Jim
Oct 15, 2013 | Miele Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 16, 2012 | Kenmore 659 Electric Dryer
Whirlpool made for Sears (Kenmore) HE4 Elite SmartHeat QuietPak9 will not respond to commands, eventually puts 20 on the time screen and the lint light comes on, won't start, won't run, checked...
send the model number,open the door look around the opening where you put the clothes in you should see a tag there.if you unplugged it and it worked then it's not any of the t-stats or door switch most likely a board issue or something to do with the cord from moving it,when you unplug it and plug it back in your resetting the board so this is what it sounds like but can't tell if you even have a board without model number.
Jan 14, 2018 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
The dryer runs and heats fine, but stops about 20 minutes prior to the end of the cycle leaving the clothes damp. IS this a heat sensor problem, and can I get a new sensor for a 12 year old model? Thank...
Easy fix. Get some windex and clean the sensors. Buildup from dryer sheets on them stops them from sensing dampness. When the dampness ain't sensed the control moves over to cooldown and off.
If their are no sensors on your model you need to swap out the heat control Klixon
Right below the duct fuse (small white) is that control.
4 wheel dryer control is here. Newer models use a thermistor
and it could very well be the problem.
It would not hurt to give it a good clean either
I have a service manual more videos and repair photos HERE
Feb 04, 2011 | Kenmore Dryers
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
My Kenmore dryer (model # 11077732795) would not shut off or heat up. I replaced the timer and thermal fuse. The dryer now heats up and the timer moves but never shuts off. Any suggestions.
Just inside the drum on the front panel is a metal sensor strip that detects a change in capacitance as the clothes get dryer. When no more dampness is read the motor is energised by the moisture sensing board. Get the goop off the sensor strips so they can send a dry message.
Mar 01, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
