Question about Pool & Spa
SOURCE: Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Posted on Mar 12, 2009
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
SOURCE: Diagnostic Message: Ec ...
press the temp button, and then press the light button, that will change the mode of the tub.
Posted on Jul 25, 2009
SOURCE: my spa leaks
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
Posted on Sep 08, 2009
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
Posted on Oct 03, 2009
Jun 07, 2014 | Jacuzzi Balboa R574 System for 1 2 Speed...
Oct 03, 2013 | Pool & Spa
Jun 16, 2013 | Pool & Spa
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Feb 22, 2012 | Pool & Spa
Jan 01, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Dec 10, 2008 | Dream Maker Spas Dream Maker Ez Spa Hot...
143 people viewed this question
