Question about Samsung Televison & Video
I have a Samsung DVD-VR355 VHS/DVD combo. I'm trying to digitize some old VHS tapes, but I'm seeing the 'tracking' notice across the screen. Can I turn that off?
Unfortunately because these tapes are so old, the tracking is constantly adjusting itself. So I'm seeing the 'tracking' adjusting bar, along with the 'VHS' 'SP' bar across the top, and that is being digitized in as well. Is there a way I can turn that display off?
Posted by Stephanie Csornok on
5 Related Answers
Bill Heronemus
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
premtech
William Rayburn
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Posted on Feb 12, 2008
Anonymous
SOURCE: Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Posted on Oct 03, 2009
Bruce Robin
  • 300 Answers
SOURCE: Stopped working and all digital figures displayed!
If the display is not dim the battery is probably OK. Try removing the battery, test it anyway, and after a minute or two replace it (I'd use a new one anyway) and see if the problem is cleared. Sometimes just power cycling will "reboot" the watch. If that doesn't do it I'm afraid it will need to visit a Breitling service center.
Posted on Apr 18, 2010
How to tune a vcr
I assume you are talking about the tracking control. Older VCRs had a control that allowed you to make adjustments within a narrow range by turning a knob and newer machines have auto-tracking. The adjustment allows very limited adjustment of electronic centering of the read heads over the recorded video track on the tape. The mechanical and electronic alignment of tape head tracking is a precision process that requires specialized alignment tools and a "standard" pre-recorded test tape. These tapes are very expensive and not as precise as one would hope. In addition, like all magnetic tapes, they stretch and must be replaced. The theory is that if multiple VCRs are aligned on the these standard alignment tapes, all machines will then track and reproduce material alike. Unfortunately, there are so many standard tapes in the world with so much variation that things do not always work well. If you cannot get your machine to play a tape recorded on another machine to track correctly, you could take it to a repair man and have him align it, but it is no guarantee it will track all the time on all tapes. That is why the world has moved on to digital recording.
Jan 11, 2015 | Televison & Video
VCR playback issues
I had a similar issue with a DVD player, in that it wouldn't play any commercial or rental DVD's, but it would play them if I burned a copy on my laptop. Turned out to be board inside the machine. I had to replace it.
Jun 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Iv got some old vhs tapes and when i put them in the vcr to play they jump and give a fuzzy picture can you help me please. thanx
All you can do is adjust the tracking and make certain the video head is clean. I would have a look inside each VHS tape at the tape itself, it might have got mould or damp inside it.
But if the video machine plays back it's own tapes and commercial tapes OK, it could be the tapes have gone bad.
Dec 06, 2010 | Sony Televison & Video
Copy tape to dvd using Q-VHQ 760 & Pinnacle instant dvd recorder. Playback looks great, unfortunately there is a thin fuzzy line at the bottom which never changes. My question - how can I fix this ? ...
Check the edge of the tape to see if it's wrinkled. That is the most common problem that shows that line. You may be looking at the head switching pulse too. Since your VCR has no tracking adjustment, it has to be done with special tools, an oscilloscope and a voltmeter. Not an easy task.
Feb 15, 2018 | Quasar VHQ760 VHS VCR
Hi On my Pansonic DMR-EZ49V, I get distortion along the bottom of the screen when playing back vhs tapes that have been recorded on an older machine, I have adjusted the tracking but it has made no...
This is a real bad problem to solve. Unless your new video has been set up badly, there's little you can do. You see it's like this either your old machine was set up badly or your new one was! To get your new one to play back the old ones would require the aligniment to be reset to the old machine settings. However when you put a new machine previous recording in - that would now badly track. A new recording (made after the adjustment) played back would be ok though.
The only way you can tell if the new machine is set up right is by putting in a commercial film video tape. If that tracks badly it has been set up wrong.
I can say this however Panasonic VCR's have a reputation of being set up well and good at tracking videos. So if it can't track the old video tape it might be well out of alignment, especially if it is not a Pansonic model.
If the old machine is still working, it would be best to play it back and re-record with the new machine.
Otherwise you would have to carry out an alignment - play back the tape and re-align back to the correct setting.
Sep 03, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Tracking
A CONSTANT streak anywhere on the screen could be a scratch in the tape itself. Losing sound, and ocassionally everything going to black and white, sounds like a dirty control track head.(The audio and control track are in the SAME head (a 3/4" metal cube that the videotape travels on). The control track section is on the upper part, and the audio on on the lower part.
If the control track head's dirty I'm sure the rotary head's dirty too! Losing audio and have tracking problems, point to dirt. And you MAY have SO much dirt built up on that head it's scatching your tapes (unrepairable), and causing you problems. Make sense?
Mar 16, 2008 | Sylvania 6260VF VCR
Blue Screen
Could be dirty heads if you have a dry head cleaner tape try it (Maxell and RCA make ok tapes to try for ~:30-1min) ALSO:
There is a delay in the time you adjust the tracking and
the results being visable on the screen on this unit,
I suspect the tracking is adjusted off center. It takes some getting used to the way this deck's tracking adjustment works as the VHS video is upconverted to be captured onto the dvd and that is what you see, the upconverted video, fed out to your TV, analog or digital, this unit upconverts everthing to digital even analog channels, there needs to be a noise/blue screen off feature in the menu like my old hitachi VHS deck and my JVC ~$60 deck has now. On analog TV or old tapes it comes in handy for adjusting the tracking/antenna.
Feb 08, 2008 | RCA DRC8335
Old Betamax Sony SL2300 Possible Tracking problems
A common problem with this model and others is the tracking pot itself fails. Wiper in pot breaks loose. Test if the tracking control has any effect?? If not, pot is bad.
Other causes are dirty heads and tape path but, the tracking control should always have some effect on PB pic. Bad video head, tape guides loose( tape not tracking on video head correctly), guide pin problem on loading ring, slack brake problem, etc.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
32 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
