Question about Honeywell Heating & Cooling
Honeywell udc 2500 controller wont go to manual?
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
How to reset Honeywell UDC2500
The procedure to restore the factory configuration on the Honeywell UDC2500 is on page 180 in the PDF manual from Honeywells website.
Steps:
1. Turn off power to the instrument for at least 5 seconds.
2. Turn power back on and simultaneously press the "FUNCTION" and the UP keys. This must be done while "TEST DONE" is being displayed.
3. If step was performed correctly, the instrument will now display "UDC" [Upper line] "UPDATE" [Lower line]
4. Press the "FUNCTION" key. The instrument will now display "DIS" [Upper] "RESTORE" [Lower]
5. Press the up arrow key. The instrument will display "CFG" "RESTORE".
6. Press the "FUNCTION" key. The instrument will display "DOIN" "RESTORE"
After that the instrument will go through a restart.
Hopefully this helps.
Mar 04, 2013 | Honeywell Udc2500 2 Output Relay Tc Input
How do l replace the electronic gas control valve on a whirlpool hot water heater tank?
Whirlpool is made by American water heater.
Gas valve is made by Honeywell.
Whirlpool electronic control is version of Honeywell 'Icon' gas valve: There are several versions of this gas valve.
http://waterheatertimer.org/pdf/Bradford-White-service-manual.pdf
Start page 24 shows: Testing, disassembly and replacement of typical Honeywell gas valve.
Whirlpool phone number 1-877-817-6750
Whirlpool manuals:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Aug 10, 2011 | Whirlpool Water Heaters
My wireless control is not working my heating is there a reset button for honeywell cm61?
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Oct 12, 2010 | Heating & Cooling
Flashing star on honeywell air controller, and air wont work
heatman101
Sep 27, 2010 | Heating & Cooling
Manual for Honeywell oil-fired boiler controller
Here is a tip that tells you how to get a manual for most any Honeywell product online...
heatman101
Sep 23, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
