Question about Pool & Spa
How do I romove unitherm govenor on raypay pool heater r266a
Posted by Doyle Meredith on
1 Related Answer
adamh294
adam hudson
  • 310 Answers
SOURCE: i'm getting an HL1 reading
Possibilities:
1-low water flow (this heater needs 45 GPM minimum to operate safely
2-blocked heat exchanger (flush exchanger through drain ports)
3-Unitherm Governor (already replaced)
4- Bad bypass assembley or bypass spring (these bypass assembleys do fail occasionally)
Id start with making sure the water flow is proper, and if that checks out ok, id replace the bypass spring and assembley.
Note: when examining bypass assembley, if spring is worn or missing, start with this only as its cheapest)
Posted on May 09, 2011
Pool heater 406A unitherm governor
make sure connected correctly not enough water passing through if you have a bypass close half way if no bypass check the maual bypass in heater might be damaged or stuck
Sep 15, 2014 | Pool & Spa
What is aunitherm govenor
thermal regulator...located inside the heaters water manifold. its spring loaded and contracts based on water temperature
Jun 04, 2014 | Raypak UNITHERM GOVERNOR KIT
Running a rheem pool heater! Hl2 error code comes on. what does that mean and what is the problem!
This is a failure measuring the temp of water leaving the heater, it has exceeded recommended temp. Water is moving too slowly through heater thus picking up too much heat.
If heater is making loud popping noises then it is without question the internal bypass assembly. Noise is water boiling in heater.
If not, I'm thinking unitherm governor is not regulating water flow.
Unitherm governor can be inspected without dismantling much of the heater in just couple minutes.
1) Turn off pump
2) with shaft of long screwdriver, I like square shaft screwdriver for this, unscrew U.G. Cap. (Find it right next to outlet plumbing, it is round cap with 4 notches.)
3) inspect condition, if it is pitted and corroded then this is likely your problem. Unitherm governor looks like a car thermostat but not interchangeable with one.
4) replace by reversing steps. The cap will hold the UG to put back into place, don't worry too much about the gasket placement.
If this isn't the problem look for anything that would inhibit water flow.
Sep 10, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Pool & Spa Logo
99 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
