SOURCE: fuel ratio for 1968 mercury 9.8 outboard
The fuel ratio is 50/1. Eg.50 gallons of fuel to 1 gallon of oil.
On an older motor and newer cleaner burning oils,you may bring that down to 45/1.Hope this helps
SOURCE: 2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
SOURCE: we have a mercury 60 2stroke outboard engine and
go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
SOURCE: Mariner 25hp 2stroke outboard. runs fine when
Change Water Pump Impeller ,
Remove Thermostat And Check To See If Opening In Boiling WAter Clean Ou Any Sand Weed etc, REfit try Again
