Question about Xerox Office Equipment & Supplies
My question is my xerox work centre machine is erro code 92-315?
Posted by C H KESHAV RAO on
4 Related Answers
pineworks
Clive
  • 4345 Answers
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
Anonymous
  • 149 Answers
SOURCE: code 014
the fixing assembly need to be rebulit or the fixing gears need to be replaced. the main fuser motor is locking up which tells them the fixing rollers have flat spots on them and have finally caused it to stop rotating
Posted on Jun 09, 2010
Anonymous
SOURCE: my machine Xerox Work Centre
my machine xerox 420 problam is U4
plz tell me the how to reslove this problam
Posted on Dec 22, 2010
lbrown1806
Lawrence Brown
  • 488 Answers
SOURCE: I need a list of erro codes and definations for
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Posted on Jan 16, 2011
XD103F Xerox work centre flashes error 7 help needed
First a fault code on your Xerox printer and or multifunction device is not always as disastrous as you might imagine, no reason to slink away from the machine. The fault code is just a way for your machine to tell you there is a problem and it needs some help. So next write down the complete code and any accompanying error message, the fault code will be numbers and/or letters and may include commas, periods or hyphens. Then find a device on which you can access the internet. At the computer or smart device go to Xerox.com and then select the Support & Drivers tab at the top. Enter the model of your Xerox printer or multifunction device in the field provided and then select the machine and select Support. On the machine support page you will see the "Search For Keyword or Phrase:" field. You can enter the fault code there or right under that field you can click on the "Fault Code Search" link. A new screen will be displayed where you can enter the fault code or you can scroll through all the codes looking for the one you wrote down from your machine
Oct 10, 2018 | Xerox Office Equipment & Supplies
Xerox fault codes
Fixya just copies and paste answers to all kinds of questions in it's answers. It is completely fake and nothing but a ad site.
May 15, 2014 | Office Equipment & Supplies
U2 error code on xerox 5020 . how to fix it?
Actualy my copier is xerox work centre 5020. My problem is machine is indicate u2 error
Mar 23, 2013 | PrintCountry Xerox 5020 Laser Printer...
Xerox DC250 error code 116 340
my machine is the xerox 7245
erros is the 116-340
Nov 03, 2012 | Xerox DocuPrint 340A Laser Printer
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
