Question about Crosley Audio Players & Recorders
Crosley 6 in 1 unit not responding to any fuction but lights on only.
Posted by CharlesandJanell... on
TURNTABLE DOES NOT WORK FOR CROSLEY CR 78CD
It could be that the switch has either broken, become obstructed, or has moved out of place.
If the unit is NOT under warranty, then you could access the deck from underneath to check on the switch.
If it is under warranty then contact Crosley. Do NOT attempt to repair it yourself.
Apr 21, 2018 | Crosley Audio Players & Recorders
My Crosley CR2405A does not work. I assume the trasformer is bad.
Usual cases in these record all in one players is the internal small fuse located after the transformer, common issue on these.
May 31, 2014 | Crosley CR2405A Mini Audio System
Arm stuck in middle of turntable won't move forward or return to rest
if the arm is automated and someone forced it to move, it could be that a gear is jammed. Open the unit to access the mechanical mechanisms and look for any stuck gears or pieces, turn on the unit and see that the motor is attempting to respond.
Dec 15, 2013 | Crosley 4-in-1 Entertainer CD Shelf System
Control panel does not respond on Crosley Dryer Model CDE4205AYJ
Don't you just love electronic controls. On the inside of the dryer is like it always was back in the day with mechanical timers. The same old problem the old ones had is the blower wheel slips and causes overheating or a ball of lint at the base of the filter chute. This eventually blows the FUSE. Their is 2 of them fuses so look close one is usually behind a shield out of sight and may have been overlooked. DIAGRAM
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 29, 2013 | Crosley Dryers
Crosley gas dryer panel lights blinking will not turn on
Hello - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately two minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
Oct 14, 2012 | Crosley CDG6000 Gas Dryer
We have a 40-pt Crosley purchased in 2005. Gave us 6 years of perfect service. It stopped working recently; it will not turn on. No lights, no response...dead. Is a unit this old worth repairing? ...
Shinn, I'd say you've gotten your monies worth out of 6 year old dehumidifier. Most of the time, it's more expensive in the end, to repair one than it is to purchase a new one. With that said, I'd vote for purchasing a new one. Just take as good of care of the new one as your did the old one. Obviously, you performed preventive maintenance on the old one and that's very important. Which makes you the exception to the rule, that most consumers don't take care of what they have and are astonished when an appliance fails.
Keep up the good work!
Mar 26, 2011 | Crosley Dehumidifiers
Odometer MALFUNTION - camry 2002
youre going to need to replace the speedometer unit.
Dec 28, 2009 | 2002 Toyota Camry
Crosley CR2406A will not record CDs properly.
I had this problem when recording CD-Rs. I switched to CD-RWs and didn't have the problem again.
Feb 18, 2009 | Crosley CR248 Turntable
Turn table
Hello Runaround. If out of warrenty and you got the 'want to' unplug the AC, lock the stylus arm,open unit up and unplug your interconnect ribbon cables one at a time & reseat them this includes the socketed ICbds as well. If the speed adjust is mechnical check for an obstruction. Good luck!
Jun 02, 2008 | Crosley CR248 Turntable
Parts
What is the model # from the sticker on the unit? I'll see if I can help.
Nov 03, 2007 | Dehumidifiers
62 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
