SOURCE: pelonis model HO157C0110 will not turn on
Bypass the 3 way (hi, med, low) switch, unfortunately it'll always be in the high position when you do this. I have done this with one of my heaters and as long as the thermostat is working properly then it will work as it should on the high setting. I took the extra step of connecting the LED light to the bypass so I know when its on.
Just remember to turn it off you'll need to unplug it.
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
SOURCE: Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
SOURCE: i need a switch for my heater,how do i order the
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
There are two knobs on it and two selector switches.
The switches you can switch on only one for half power and two for full power.
One knob is the most important the thermostat which set the maximum temperature to reach in the room and when it reached it switch off the heating elements. Adjust to most comfortable one for you, it is not in degrees scale but in number 1-9 but you can test it and decide.
Final the knob that has all these small teeth
