There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller.
Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device.
You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb."
If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller.
If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need.
Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
