Question about OKI Office Equipment & Supplies
This is to replace the internal drum elements - which I've already procured, but without instructions. Also any tips on where to replace the drum chip not the toner chip would also be great. - TIA
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
SOURCE: Oki C3300 toner replace, where do I stick the new chip
On the top left hand side of the cartridge, usually where the letter representing the colour of the toner (in your case M for Magenta) appears, there is a small removable section, about 15mm by 20 mm in size. Prise this open with your finger nail or small screwdriver. Remove the old chip and insert the new one in here.
Posted on Aug 03, 2009
SOURCE: I have a new OKI B410d printer which is givng
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Posted on Sep 14, 2009
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
Posted on Jan 30, 2010
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Posted on Mar 29, 2010
May 08, 2014 | OKI C Office Equipment & Supplies
Jan 15, 2013 | OKI C5500n Printer
Jun 10, 2011 | OKI B4400 Laser Printer
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
Nov 29, 2010 | OKI B4350 Laser Printer
Sep 17, 2010 | OKI C5100n Laser Printer
May 21, 2009 | OKI C5200n Laser Printer
Mar 10, 2009 | OKI C5500n Laser Printer
Feb 12, 2009 | OKI B6300 Laser Printer
Nov 13, 2007 | OKIPAGE 8W Led Printer
50 people viewed this question
