Refrigerators Logo
A
Anonymous Posted on May 19, 2019
MPF8202 Pizza Prep Table ALARM MESSAGE P1
ALARM SOUNDING AND P1 SHOWS ON TEMP SCREEN
Cheryl Foster
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on May 19, 2019
Cheryl Foster
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
5090
Points
41
P1 is usually the code for a temperature probe error - the refrigeration should now operate on a time cycle until the temp probe is replaced
5 Related Answers
Dennis Boxerman
  • 1306 Answers
  • Posted on Jun 13, 2010
SOURCE: I got a true refrigeration sandwich prep table it ...
Look for doors not properly closing, poor air flow over coil or something blocking air flow, improper freon level.
http://www.truemfg.com/pdf/InstallManuals/TPP_TSSU_TUC_TWT/tuc_english.pdf
check out this web site as it has a manual for your equipment. it has lots of good info. Hope this helps. If you need more help, let me know.
Anonymous
  • 83 Answers
  • Posted on Apr 27, 2011
SOURCE: My pizza prep-table freezes everything.
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Anonymous
  • 43501 Answers
  • Posted on Jul 20, 2011
SOURCE: my pizza prep table is
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
espressonist
espressonist
  • 1711 Answers
  • Posted on Aug 31, 2011
SOURCE: PIZZA PREP TABLE BEVERAGE AIR
If you had a repair person to replace the compressor the you should not need to anything more. We believe the repair man have check also of the evaporator and condenser were working ok since from what we undestand he did not mention that they have any problems. So the problem is either the compressor starting kit is not working properly or the repair man left some wires loose. The second posibilty the freon charge is not the proper one and need to be check again if the gas pressure low and high are ok. Finnaly every time we replace a compressor on comercial refrigerator we also replace the freon gas filter if he didn't then there is a posibilty after the compressor replacement the filter to be goggle. As you have already notice from repair person in order to deal with freon gas you need special tools and also you need to have a national licence. Also if you have paid so match money for the compressor replacement then you should demand from them to check why the fridge still have problem to low down the temperature, if they have done a poper jop then the fridge would work better than before.
iam6fan
Chris Huff
  • 6289 Answers
  • Posted on Oct 18, 2018
SOURCE: Hi i am getting a P1 error on a HOBART AM15 ELECTRIC DISHWASHER
Most likely sump temperature probe needs replacing.
Operation pressure
suction pressure should be about -4 inches of mercury and discharge pressure should be around a hundred and fifty. do not put the gauges on to the suction line while is running or you will draw air into the sealed system. attach a gauge is only when the unit is off and equalized
Appliance 911 Sea Breeze
1helpful
Metalfrio prep table freezing evapoator
Check that all vent areas are clear of any dust or food packaging. If you have ice build up it needs to be thawed out also because it will only continue freezing until it gets proper airflow.
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib
www.manualslib.com > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Expose access to condensor to a true tpp-93 pizza prep table
Typically most True refrigerators you can access the condenser coils on the units either from the back or from the side of the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Traulsen upt 488-lr owners manual I simply want know wich way to turn the screw to decrease the refrigerator temp.
Generally with commercial refrigeration thermostats, you will need to turn the screw clockwise to get colder. It is recomended to adjust in small increments and allow the unit to stabilize before the next adjustment. It is easy to go too far.
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Regards
Gordon
Its freezing my product
It is freezing your food? What brand is this? Have you checked your climate setting?
I need full construction plans on how to build a pizza oven out of brick
http://www.fornobravo.com/pompeii_oven/pompeii_oven.html
this site has alot of different options with plans available for you
good luck sounds like a cool project
I have a Randell 5ft Pizza Prep table that's not working correctly and was wondering if someone might be able to help me? The top rail is cooling like it should but the bottom storage area is NOT cooling...
This unit uses Thermostat/Solenoid Valve Combination's to control the temperature
1. Rail 2. Bottom Storage
The way it works is the thermostat senses the need for cooling and energizes the solenoid valve. This allows refrigerant flow which cools the area it is controlling. Once the thermostat is satisfied the contacts open and the solenoid is de-energized closing the valve. If the solenoid is bad, the valve remains closed, no refrigerant flow, warm unit.
Test the solenoid coil (two wires) to see if voltage is present either with a volt meter, or remove the coil off the valve and place a screwdriver (insulated) through the coil hole and you should feel the pull like an electro-magnet (what a coil is).
Why is there water pooling in my sandwich make up table? My reach in cooler, also?
During the cooling/freezing cycle condensation forms, this drips into a pan and then is evaporated by a heating element.
One of two things could be wrong.....
Your drip pan is clogged
or
your evaporator unit is bad
Hope this helps
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
