Question about Pool & Spa
My pent air pool heater was working then shut off, it is giving me a E 03 error code
Posted by Frank Vito on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
Delita Foltz
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
Kieran Ruppert
  • 990 Answers
SOURCE: I have a AquaCal Heatwave H125C-A Pool Heater.
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Posted on Jan 26, 2010
Anonymous
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
Anonymous
  • 5 Answers
SOURCE: I have a e05 error
check the sensor that is on the exaust
Posted on Sep 09, 2010
H:ow can I get my pool heater to stay on?
Is your heater giving you an error code? When it shuts down, which light is on, "service system" or "service heater"?
Aug 24, 2014 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Why does my hayward h250fd have and if error code? it is a brand new heater
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
There are a few reasons that this might be happening. They range from air in the gas line to inadequate gas flow. Start by checking the installation
Aug 08, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Raypack 2100 pool heater runs for a couple of minutes then loud banging noise. heater shuts off and error code HL appears
That HL is your high limit shutting the heater down. The banging is the sound of water boiling in the heat exchanger because it is moving too slow. This is almost always the result of the bypass or governor (thermostat) not working properly, so too much water is bypassing the heater. It's not too hard of a fix.
Dec 17, 2013 | Raypak RP2100 DIGITAL POOL HEATER R265
How much pent air new model?
What size of heater do want.
Cant guess what price to quote if you don't have a model of heater to price out.
Nov 07, 2013 | Pentair Pool & Spa
Heater shuts down and message says "Fan Lockout".
Shut off the breaker to the heater and turn it back on to reset heater and clear error code.
Oct 16, 2013 | Rheem 266K to 399K BTU Swimming Pool...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Sta rite 400na gives error code 05 after about 30 seconds
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Pool & Spa Logo
119 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
