Question about Baby Gear
I have Superwide Safety Gate #1176. It says 56"- 72'. How do I make it 60?"
Posted by Julia E Bishop on
doobuster
    New Friend:
  • 47 Answers
Https://images.homedepot-static.com/catalog/pdfimages/67/67061cc4-63b8-44b9-a1ee-7434d5b50da1.pdf
Seems as though it is adjustable easily in the linked instructions
Posted on Jun 05, 2019
Need replacement parts
I need the same, but this is the best I can find but not sure if will do the trick for the Top Paw tall gate I have. Did you find a solution? http://www.gates4pets.com/bindaboo-pet-gates/gate-accessories/replacement-hardware-parts-for-gates-white.html
Dec 01, 2013 | Top Paw Extra Tall Pet Gate with Small Pet...
If you bump into the gate, the gate stops and it doesn't go back why?
Check in the control box for a safety sensitivity adjustment screw. It probably needs to be increased a bit. Or, it may have a switch for two settings. one for stopping and one for rebound. Hope this helps
Oct 05, 2012 | EDGE Tech Corp Miller Edge Mgs20 5' Gate...
Espresso swing gate
Hi
If you have a problem with your Safety 1st Wooden Swing Gate we recommend you return to your retailer with your proof of purchase to discuss assistance, exchange or refund.
Apr 22, 2012 | Safety 1st Wooden Swing Gate Espresso
How do i open a first year everywhere gate
You grab the grey handle and pull upward to release. Then slide the gate open.
Feb 23, 2012 | The First Years Everywhere Gate
We lost the directions to install the gate and can't figure out the handle/how to latch and unlatch?
from evenflo.com
Evenflo Child Safety Gates
  • New one-hand Lever-Locâ„¢ mechanism -- simply squeeze the buttons and push down to open
  • Smart design cuts installation time by 75% -- pre-assembled for 5 step installation
  • This child safety gate swings in one or both directions for easy walk-through
  • Red/green indicator shows whether gate is properly locked
  • Adjusts from 29" to 42" wide, 30" tall
Jun 14, 2011 | Evenflo Secure Step Top Of Stairs Gate -...
My elite gate won't close. the charge ok led light is not on. checked everything and it's ok. switch limit switch on both sides works fine except when trying to close, it won't run.
If you disengage the motor does the gate slide easily? if not that could be the problem, most gate control boards have a sensor that detects the current drawn by the motor, if the gate hits an obstruction or is jammed the motor draws more current and the sensor stops the gate moving. It could also be a problem with the safety sensor, to check this locate the safety sensor input on the control panel and bridge the 2 contacts if the gate then works the safety sensor is the problem.
Dec 28, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
How do I purchase new hinges for the baby gate?
Looks like you have to call the company.
I need to replace hinges for the safety 1st Perfect Fit gate and will do soon. If I remember, I'll provide an update.
Dec 27, 2010 | Safety 1st Perfect Fit Gate Fits 30" 42"...
Cobra laser 360 11 band
Assuming the model number is COBRA XRS 9500CS 11-BAND RADAR/360*
LASER DETECTOR WITH DIGVIEW DATA DISPLAY
& VOICE ALERT
This is what we can find out about it.
DETECTS 5 RADAR SIGNALS: XBAND, KBAND, KA SUPERWIDE, VG-2 RADAR DETECTOR-DETECTOR, SPECTRE 1 RADAR DETECTOR-DETECTOR
DETECTS 4 LASER SIGNALS: LTI 20-20 LASER, ULTRA LYTE LASER, PROLASER, PROLASER III
2 SAFETY SYSTEMS: SAFTETY ALERT & STROBE ALERTS DIGVIEW DATA DISPLAY & VOICE ALERTS
http://www.fixya.com/support/p237601-cobra_xrs_9500cs_radar_detector/manual-313
I again assume the above model number......
Hope this helped some...
Kevin
Mar 24, 2008 | Radio Communications
Baby Gear Logo
142 people viewed this question
Top Baby Gear Experts
Marvin
Marvin
Paul Carew
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
