Question about Frigidaire Ovens
I am trying to find a wiring diagram for a Frigidaire wall oven model Reg533hm*0 I have searched online but cannot loc ate. Any ideas?
Posted by Al Samsel on
Jeff Harms
    Sergeant:
  • 264 Answers
Check with a local repairman. He should be able to locate if it is still available.
Posted on May 19, 2019
5 Related Answers
Anonymous
  • 333 Answers
SOURCE: need manual
Click on this link and then look on the rifgt and click on guides and manuals. that will take you where you want to be. I hope this helps. http://www.frigidaire.com/products/cooking/built-in_ovens/single_gas/prod_FGB24L2A.asp
Posted on Dec 07, 2008
Anonymous
  • 56 Answers
SOURCE: i have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Posted on Jun 30, 2009
Anonymous
  • 476 Answers
SOURCE: need a diagram of wiring for a gas wall oven to
As far as I know almost all kitchen appliances have a wiring diagram of all electrical connections. usually found on either of the side panels(if they are removable) or inside the control panel where the temperature and the rest of the knobs are located, but if yours does not have one you will need your oven make and model number and refer to the following websites for the diagram : www.partselect.com or www.repairclinic.com.
Posted on Jan 29, 2010
Anonymous
SOURCE: NEED A WIRING DIAGRAM FOR A GE
Click on the link below to view the wiring diagram for your electric oven
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216042
Posted on Jul 07, 2010
seth adams
  • 1531 Answers
SOURCE: I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Posted on Nov 28, 2010
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Sep 27, 2014 | Frigidaire 24" Single Gas Wall Oven with...
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
We have a Frigidaire Wall Oven that shows Err F3 - no buttons work. Model FSC88B-4 . The Oven temperature sensor measures at 1089 Ohms. There is 5 VDC on the control board. Tried resetting by removing the...
The sensor checks good. The only thing left to check the wiring between the control and the sensor. Check this for opens and shorts. If all checks good you will need to replace the EOC electronis oven control / clock. You can get diagrams and illustrations at www.appliancehelponline.com by entering your model #. All parts come with installation instructions.
Apr 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
Ovens Logo
132 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
