SOURCE: MAKITA DC1290A CHARGER PROBLEM
The DC1290A charges 9.6 volt and 12 volt batteries. I have found two problems that occur causing problems. First is cold solder joints on the pc board. Second is a possibly bad SCR that's bolted to that standup aluminum bracket. The original parts is a type T106D1 which crosses to either an NTE 5457 or NTE 5458 replacement. Watch out when removing the pc board from the top case. The little blue microswitch actuator which moves when a battery is inserted can fall out. Also when reassembling the pc board into the top case, be sure the thermistor slides into it's "pocket" before fully seating the circuit board.
SOURCE: Ihave 110 volt makita dc18rc battery charger,
I had the exact same problem. I ordered the ZNR V10 241U part from Dija Key. They are around 36 cents if you buy 10 of them. I cut the old one out and soldered the new one in. I changed the fuse over to an automotive one so the fuse is easier to obtain. I plugged it in and charger works fine.
What happens is a voltage spike either low or high gets recieved by the charger. The fuse appears to be slow blowing and does not stop the spike in time. The spike is stopped by the varactor surge supresser. In doing so, it saves the circuit board so all you have to replace is the fuse and the surge surprsser.
