Question about Samsung Televison & Video
Where is the inverter board on a Samsung UN55J6201AF
Posted by Charles Darcy on
b1jqxk44
    Habit-Forming:
    New Friend:
  • 157 Answers
The inverter broad is part of the power broad.
Posted on May 19, 2019
Does Samsung make inverter boards for Hisense LCD40V86P, my repair guy says I must buy a Samsung inverter board model INV40N14B. Hisense doesn't make the models any more
Hisense actually made several boards that are used by many manufacturers. This may just be a case of the only hisense boards still being available are ones they made for samsung.
Jul 12, 2016 | Samsung Televison & Video
Finding my Led inverter and/or driver on my 60inch Samsung. UN60FH6200
The inverter is generall right under the led panel on the front. It's a skinny rectagular controller board that connect to the led panel
Jun 22, 2016 | Samsung UN60FH6200FXZA 60 Inch 1080p Smart
Samsung LED TV half screen is black
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 11, 2016 | Samsung Televison & Video
My Samsung TV 46" LNT4671F
Hi:
This is due to low voltage getting to the Inverter board or the Inverter board on the bad side is not lighting the lamps. Usually bad capacitors or the power supply and the inverter will cause this symptom. You may want to replace both inverters boards on this model, new models have one inverter board for both sides of the backlight.
Nov 10, 2010 | Samsung Televison & Video
Samsung lcd ln46a530 is having some difficulty turning on and when i does turn on the picture drops out( blank) but the sound stays on.
The tv have 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these refurbihes 2 long LCD inverter boards for the replacement.
Oct 27, 2010 | Samsung LN46A530 46 in. LCD HDTV
Our 22 in Samsung Series 3, 350 only has sound, no picture. Is this a simple problem to fix?
Yes,Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries these Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is long in shape.
Mar 17, 2010 | Samsung LN40A550 LCD TV
Televison & Video Logo
49 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
