Question about LG Washing Machines
Lg combo fills up with water. stopped mid cycle last time filled with water. Is it a water valve or control board issue?
Posted by Roger Shrute on
  • Roger Shrute May 19, 2019
    Fe error code. Ran diagnostic test. That went fine. Water isn't leaking into machine when not running.
  • robert May 19, 2019
    Most likely one of 3 things: fill valve, water pressure switch/pressure switch hose or drain pump. If you put machine to spin cycle and it drained the water out normally, then the drain pump seems to be working fine. So start with water pressure switch and hose. Check videos out from: repairclinic.com or AppliancePartsPros.com or YouTube.com. Good luck.
robert
  • LG Master
  • 2,548 Answers
No error codes?
Posted on May 19, 2019
5 Related Answers
Anonymous
  • 878 Answers
SOURCE: Washer fills slow only in the rinse cycle
The first thing I would do is remove the hoses from the inlet valve and make sure the screens are not clogged in the valve. On some models the valve will compensate on fill opening both hot and cold. It will not do this on cold rinse. Before ordering any controls check this out first. If it's still the same I tend to believe it's a valve problem. The buzzing you are hearing is the valve. Catriver, post back.
Posted on Aug 06, 2006
Anonymous
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
Anonymous
  • 306 Answers
SOURCE: Blanco Dishwasher BIDW605 does not
I would check the hose/water filters. make sure that you have proper flow from the hoses
Posted on Apr 04, 2008
Anonymous
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Washer stopped working mid cycle. Filled up with
Hello, Welcome to FixYa. The scenario you describe is usually associated with a faulty or broke lid switch...but I don't know if you checked that yet or if you know how.
The lid switch failure is definitely a common top load washer problem. Here`s how you can repair it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...but it should cover yours)
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know how you make out. If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video'
I will try to help in any manner I can of course as well. Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Posted on May 20, 2011
LG WM3987HW Combo - drum is filling with water during dry cycle.
Sears Parts Direct is one source of the parts diagrams, https://www.searspartsdirect.com/model/1vc37q1bdj-003204/lg-wm3987hw-washer-parts . See the Dispenser assembly parts diagram for the water inlet valve. If you can watch the entire cycle, try turning off the shut-off valves for the washer inlet hoses after the rinse cycle and before the dry cycle starts. Water should not flow into the washer/dryer with the shut-offs closed.
I've seen inlet valve solenoids fail in the open position or in the closed position. I've never seen a control board that sent open messages randomly. (Sometimes, there is damage to the control board or corrosion or damaged wiring that stops the control board from sending the open/closed message to the solenoid.)
I hope this helps.
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
1helpful
LG front load washer continues to fill with water after spin cycle
Bad water valve or main board. the water valve closes when it stops receiving voltage from main board. If it's not closing then valve is bad.
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Enter your model number to see parts for your washing machine.
Help me find my model number
Water Inlet Valve
Main Control Board
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
The water starts to come through then just stops and then alarms go off
2helpful
Washer stops during rinse cycle and beeps at me
Whirlpool 1000 w100 stops after filling with water
Agitator starts wont quit
see the diagram
Washer stops at rinse cycle and give the ul code F1
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
