Question about Crosley Washing Machines
Crosley caw9244bw0 not spinning - Crosley Washing Machines
Posted by Brenda Ortiz on
Washer will not come on, I have checked the power supply and its good. Is there a way to reset electronics besides unplugging?
Are you saying that the lights are no coming on and there is no action at all? If you have no power at all you will no be able to perform diagnostics. You can look and see if the control board is receiving power by checking the L.E.D. light on the board. To access the board you will remove the screws going across the back of the console and then with a putty knife depress the clip on either end of the console from the front and tip it toward you. Please be super careful because there is electricity in this area. We don't want you to be come damaged with servicing your machine. If you need further assistant I am here to help.
Feb 05, 2016 | Crosley Washing Machines
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
How to clean screen water barely running in
Pull hose off and use a small screw driver to pull screen out and clean then put back in
Feb 01, 2014 | Crosley Washing Machines
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
My turntable does not spin
On my Crosley there is a switch on the back for either Phono or Aux In. Make sure it is set to Phono or the turntable won't spin
Jan 08, 2010 | Crosley 0187SST Turntable
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Extra loud noise when spinning
most likely the main spin bearing at the top of the transmission just below the spin basket and seal
the bearings dontjust go out for nothing either,you will need to be replacing the tub kit seal also
not the easiest of repairs,may need special tools to remove the seal nut assembly...
Mar 17, 2009 | Crosley Washing Machines
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Crosley Washing Machines Experts
peter gittos
peter gittos
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
