Question about Watches
I was wanting a return label to return a watch which is very cheap looking and not what I was expecting it to look like.
Posted by Nancy Wibben... on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Watches Master
  • 35,541 Answers
Goody for you since you failed to buy it here
Posted on May 18, 2019
I have water condensation in the face of a brand new (bought from an ebay watch store) bulova water resistant (up to 100m - it says 100m on watch face) women's marine star watch. what are my options?...
If you have registered your watch with the maker, then it is bes to send it to them (talk to them about it first- go to Boluva.com and look for service centers).
The seller would probably just send it off anyway and increase the delay time to gettingit back.
All work should be done by one of their service centers or an authorised dealer, in order that the warranty is not affected.
With a cheap watch the answer would be to remove the back and put it in a warm dry place for a day or so but as yours is not in that catagory, I would not advise any DIY methods.
I know its' a pain to loose your watch for a time but only accredited service agents can guarantee the water resistance it a watch is opened.
Jul 23, 2011 | Watches
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 | Watches
    R they any good
    mcdevito75, Tag Heaur, one of the finest watches around, an old company and high end quality watches, Tag Heaur watches very, very good watches, high collector value, also expect a price tag on your tag Heaur watch, as they are not cheap.
    Oct 16, 2010 | Tag Heuer Link CJF2114
    I do not know how to set my daughters digital watch from walmart. It does not have a manual.
  • Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • Step 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • Step 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • Best I can do for you not seeing the watch Good luck
  • Aug 12, 2010 | Watches
    How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
    The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
    Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
    When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
    Coleman 40-408 User's Guide
    Nov 03, 2009 | Bulova Watch
    I have a fossil watch with ES-1426 3000601 model number. Wanted to know if it's fake or genuine. Where can I find the authenticity of this? A friend just gave it to me.
    Be sure it is genuine as the Fossil watches are not in that league to make fakes. Even fake watch manufacturing needs a significant money investment,so, expectations for quick turnaround and investment recovery are common. This would not be possible with fake Fossil watches as the average price is about £70 for original and this is comparably low price in watch market.
    Don't be scared away by this- Fossil is good brand: they just using cheap labor and parts, at the same time offering good looking and quality watches to masses.
    Rate me, please.
    Aug 22, 2009 | Fossil CH2473 Watch for Men
    I need to know if I need to purchase a watch winder for my TAGs
    Use a winder if you must but I recommend just winding and setting when you want to wear them as most winders I have seen are very cheap and unreliable. Expect up to 50 hours from most watches usually not less than 30, this is if the have recent< 5 years, overhaul.
    Jun 11, 2009 | Tag Heuer Link Automatic Chronometer...
    I cant find where to buy a new watch band
    Dear Friend,
                     U can Purchase a new branded watch at Fast track which is one of the best brand among the watch companies.If u need to buy am Indian Brand then u can take a choice of Titan
    Regards,
    Aysaam
    May 05, 2009 | Casio G-Shock GW500A-1V Wrist Watch
    Watches Logo
    123 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
