I am trying to add another device and it tells me sync services are no longer available
Posted by Russell Cottrell on
How do i add gmail calender in iphone
Follow the steps carefully
  • First, lets make sure your Calendar is properly synced. The process is the same on both devices.
  • Go to Settings, then open Mail/Contacts/Calendars.
  • Next, select Add Account and Gmail. However, if you have already added your Gmail account, then instead of Add Account, choose Gmail from the account list.
  • Toggle the Calendar switch to On.
  • Otherwise, add your Google account information and a description of the calendar, and ensure that the Calendar option is switched on. Syncing will begin when you next open the Calendar app on your iPhone or iPad.
  • Read more: http://www.digitaltrends.com/mobile/sync-multiple-google-calendars-on-iphone-or-ipad/#ixzz4IDyLCSHv
    or
    Visit here:-http://www.iteraa.com/gmail-customer-service Gmail Customer Service
    Aug 24, 2016 | Google Computers & Internet
    How do i delete an email account from a xperia x10 mini?
    The Sony Ericsson Xperia X10 supports multiple accounts for Gmail, Exchange Activesync, Facebook and other services. Here, we show you how to add and remove accounts on your Sony Ericsson Xperia X10.
    Adding an account:
    1. Open Settings, the tap on the Accounts & sync selection
    2. Tap on Add account
    3. Select the type of account to add (Microsoft Exchange, Facebook and Google are available by default)
    4. Follow the on-screen instructions to configure your account (depending on account type, you will be asked to select what kind of data to sync to your device)
    5. When complete, the account is added to the list in the Accounts & syncsection and data will begin synchronizing to your device
    Removing an account:
    2. Tap the name of the account you wish to remove/delete
    3. Tap Remove account
    4. Confirm that you want to remove the account by tapping on Remove account or tap on Cancel if you selected the wrong account
    5. Your account will now be deleted thanks
    Jun 28, 2011 | Sony Ericsson XPERIA X10 Cell Phone
    Looking for sync software for Axim x51
    ActiveSync is all you need to sync with your Axim. Make sure you download the appropriate software for your OS. Drivers are available at microsoft.com
    Jan 28, 2010 | Dell Axim X51v Pocket PC
    Sync Notice
    This usually indicates that the content you are trying to listen to has digital rights associated with the media. This woud normally be the case if the content was downloaded via a subscrition service such as Napster or Rapsody, which means you are basically "renting" the song instead of buying it. In order to validate that the subscription for that media is still valid (i.e. you have paid for the subscription) you must sync the device with the service on a periodic basis. For example, with NapsterToGo you must sync a device at least every 30 days to validate the subscription.
    Jan 05, 2009 | SanDisk Sansa m240 MP3 Player
    Windows media player won't let me sinc
    The firmware for RCA devices is not currently available and will no longer be, according to costumer service. Audiovox is not supporting the old devices like the opal. I guess when companies change hands it is no longer important for them to support the previous company's devices.
    Dec 26, 2008 | RCA M4204 MP3 Player
    Sync???
    Sync the device to Rhapsody, Napster or whatever music service you use to prevent the license from expiring. If you have already cancelled your music service, you will no longer be able to use that song unless you renew your subscription.
    -Tha Mp3 Doctor.
    Dec 13, 2008 | RCA OPAL M4001 MP3 Player
    Music
    Make sure you have synced the songs properly. Try the windows media player. Sometimes when you add songs it just adds it to computer part but does not sync. If u can add how downloaded the songs to your description.
    Feb 27, 2008 | SanDisk Sansa e250 MP3 Player
    No access to songs
    Several possibilities:
    When you first synced your player to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the player. Now, every time you sync you device, it adds every new file from your computer into the player automatically. It will even delete songs from your player that were on there before.
    Go into Windows Media Player 11 with your player connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding/deleting songs/files you don't want into your player.
    If this does not work, then:
    Make sure you back up all songs on the GoGear before attempting this solution.
    1) Back up all files on the GoGear
    2) Open up Philips Device Manager (Start --> All Programs --> Philips)
    3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
    4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
    Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
    -Tha Mp3 Doctor
    Dec 21, 2007 | Philips GoGear HDD6330 MP3 Player
    I cant download music
    Music Service or from CD
    Oct 06, 2007 | Dell DJ Ditty MP3 Player
    Sync loss on outlook
    You go to your toolbar and right-click on the icon. Select custom. On the drop-down, secect your hotsync name.. make sure the contacts and other built-in conduits (date-book, memos) are set to desktop overwrites handheld.
    Sep 14, 2005 | Samsung SPH-i500 Handheld
    20 people viewed this question
    Muntejaya Ginting
    Muntejaya Ginting
     Grubhead
    Grubhead
