Question about Samsung Televison & Video
My Samsung TV UN50H6203AFXZA AH01 has horizontal and veritcal lines in left half. Center to right half has Band.
Watched you tube videos and Jimmy.com. Some advised it is a bad Tcon board. Jimmy advise it is a LCD panel. What should I order ?
Posted by Ilesh Patel on
kb0nly
    Novelist:
  • 100 Answers
Its probably a bad T-Con board as long as the screen itself isn't physically damaged, no cracks, etc. But if the T-Con board won't fix it then its not worth fixing, its going to be hard to get a replacement LCD panel, if not expensive compared to a new TV. If the T-Con board is cheap enough it might be worth a shot to try that, and if it doesn't fix it then its time for a new TV. Sad but true on these!
Posted on May 19, 2019
5 Related Answers
Eduard P
  • 71 Answers
SOURCE: DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Posted on Dec 10, 2007
pishta68
Steven Wander
  • 594 Answers
SOURCE: Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Posted on Feb 17, 2008
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
jerry_kramer
Jerry Kramer
  • 3904 Answers
SOURCE: Red lines on Samsung UN46B7100. Is this the TCON board or the panel?
Have you checked all cables first? Color fluctuations and problems of this nature can be caused by a bad VGA/HDMI/Component cable. Try plugging your source device into other inputs and see if you get the same result. If that happens you more than likely have a bad video card.
Posted on Aug 31, 2012
SOURCE: sanyo lcd tv picture has stopped working
Could be several things going on but the unit will need to be diagnosed to be sure. I would start with checking the t-con/LCD panel ribbon connections. Outside of that could be a defective t-con or LCD panel.
Posted on Oct 12, 2012
Horizontal lines on LG TV
I hate to give you bad news but about 90% of the time horizontal lines come from a bad panel and if that's the case the set isn't worth fixing as a panel costs hundreds of dollars
Mar 24, 2018 | LG Televison & Video
My SAMSUNG PPM42M6H screen has horizontal grainy lines at the top of screen measuring about 7 inches and from right to left. Lower half seems OK. What should be done or replaced?
Check the ribbon cables in side the TV that connect to the panel. They are the left side looking at the back. Make sure they are all seated propporly. If that does not fix, then your Upper Y Buffer board needs to be replaced.
Apr 10, 2012 | Samsung PPM42M6H 42 in. Plasma TV
One line of pixels out in center of TV
Sounds like a defective screen, call Apex Digital support.
Jan 03, 2010 | Apex Digital LD4088 LCD TV
KDL-40S2000 horizontal black lines
Seems T-Con board mounted at top center at rear of LCD Panel is bad.
Local TV tech will fix TV by replacing T-Con board.
Thanks.
Aug 30, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Televison & Video Logo
23 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
