Question about Samsung Televison & Video
Hello, have the Samsung tv model # LN32A330j1N, getting a yellowish color on the tv. Can't hardly see any ones face . Just colt all over the tv . I can hear the tv
Yellowish color on tv model# LN32a330j1n
Posted by Raymond Oscar on
Stephen Miller
  • Samsung Master
  • 1,645 Answers
Posted on May 18, 2019
4 Related Answers
Anonymous
SOURCE: Color of picture on all channels in yellowish
Your optical block, also known as a light engine, is going out. I actually just had mine replaced today!!!!
Posted on Dec 17, 2009
Anonymous
SOURCE: picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Posted on Jan 11, 2010
SamTbone
  • 26 Answers
SOURCE: samsung LN32A330J1N LCD T.V has no picture when powered on
I have a LN32A330 with a cracked screen. I can sell you boards tha you may need or maybe i can purchase your non working set.
Please email me, [email protected]. You may need your power supply repaired. I am able to repair it for you if needed.
Posted on Jan 27, 2010
ray gallant
  • 68542 Answers
SOURCE: How do i fix the video on my 19 inch flat screen TV?
had to scrap two of them this year . just kept kicking off .
Posted on Dec 18, 2014
Dec 18, 2014 | Televison & Video
Can I download a manual for a Samsung tv #ln32a330j1n
These days just google the user manual for almost anything. Usually the manufacturer will have it. There are also independent sites that pop up that usually has the manual you need.
Personally, I couldn't find a manual for an old GE Hot Water Heater.
I went to their site. No Manual. Emailed there CS and they emailed me the PDF manual for my discontinued model quickly
Sep 18, 2014 | Samsung Televison & Video
LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Jan 22, 2010 | Televison & Video
Samsung LN32A330J1N LCD T.V has no picture when powered on
This can be one of two problems. The backlight inverter board is bad # BN44-00235B <or A $60-80
Or one of your backlights is bad/broken. Not a easy repair. Single lamp is about $16-25 whole kit $150. But finding a great tech who can or will take the screen/light box apart to do it will be the biggest task. Takes about 3 hrs to do. And if you do NOT know what you are doing,you will damage the screen.
Then you just throw it away. But if your lucky, it might just be a bad connection. If it comes one after it goes off. But if it just flashes on for a couple seconds then does not come back on, Most likely bad backlight/or inverter. It goes in to protection mode.I have seen in a couple of Sony's it being the T-con board "LCD control"board do the same. $60-125
I wish I could give you better news. It is not easy to tell the problem on that without testing out each lamp "15-20 of them w/a lamp tester" or checking out each transformer on the inverter board. Verry time consuming. This is why I push the Extended Warenty. LCD's still have bugs to weed out. Plasma's are even worse.
Jan 16, 2010 | Samsung LN32A330 32 in. LCD TV
Dec 11, 2009 | Televison & Video
Picture is starting to get greenish, yellowish colored
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Feb 28, 2009 | Samsung PCK520R TV
Greenish yellowish tint on the tv
I have been advised that the color/light engine of the TV fails often and will typically create a green tint on this unit. I have one on order to get a replacement installed. BTW, it is not "user serviceable" and (for me) will require moving the TV to the repair shop for the change-out.
Nov 11, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Ekse
