Question about Pool & Spa
Menu button on my Aqua Logic pool controller stopped working.
I have a remote Aqua Logic pool controller on the wall of my porch. The digital reading works and the buttons to turn the filter on and the pool cleaner on work but when I press the menu button nothing happens. What's wrong?
Posted by Bruce Flechter on
5 Related Answers
Anonymous
  • 192 Answers
SOURCE: blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Posted on Sep 23, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
Anonymous
  • 70 Answers
SOURCE: The menu button on my remote doesn't work
Try replacing batteries. If that doesnt work try aiming directly at Receiver's sensor. If all the other functions work except the menu see if you can access menu directly from the unit itself. If it works then you might need to replace the remote
Posted on Oct 13, 2008
tolexade
Adegbola Toluwalope
  • 81 Answers
SOURCE: Gateway FDP1975W Monitor Power Button Not Working
i would advice you to take your monitor to a technician, but if you are not ready, please leave the monitor on and make sure it is connected to ups u can now turn it on and off from the ups, if you continue the menu, Auto fit etc stuff, you might damage or disorganize the settings of your monitor which might cost you more. thanks
Posted on Jul 17, 2009
deababrata
ASHWINI KUMAR
  • 66 Answers
SOURCE: My storm's Menu button won't work. I mash the
it is software problem
Posted on Oct 23, 2009
Testimonial: "Thanks I carried my Storm back to Verizon and I'll be getting a new phone. This will be my 5th phone. I love the phone but tired of the problems."
Communication error 2 means and requires what steps to correct?
See update below: Problem recurred.
I have a Hayward Goldline Aqua Logic Automation and Chlorination System. Back in February, I noticed that the indicator lights were either flashing or "all on" or "all off." The LCD screen still functioned, so at least I could still operate the controls and see on the screen whether I was activating the spa spillover, spa, pool, or pool heater. I could still set the timers, etc. So I lived with that for a while, since a new PS-8 control panel isn't cheap (about $400.)
A few days ago, I noticed the "Communication Err2" message and Hayward's toll-free number below it. None of the buttons responded or did anything. No beep. Nothing. I turned off the breaker, waited, and turned it back on. The pool system would reset, but then within a couple minutes, the "Communication Err2" message returned. After a few times doing that, the control panel stopped responding altogether.
Even though I couldn't use the control panel, the pool filter was still automatically turning on and off at the times I had set. That probably meant the circuit board was still good, but the control panel finally needed to be replaced. So I bit the bullet and ordered it. The new PS-8 panel arrived today and I swapped it out. Voila! Everything works now. (big sigh of relief.) No more error message.
12/21/2017 UPDATE: The new PS8 panel worked for about two days, then the Communication Error came back. At first intermittently, then after another day or so it was permanent; once again I couldn't use my pool controls. After a tech came to the house and said he'd have to call Hayward during business hours so they could "talk him through" a possible repair, I called a different Hayward-authorized service. That person told me to check and see if there were any remote connections plugged in; those can cause communication errors if they get shorted out. I removed the front panel of my unit and unplugged the connections for the Aquaconnect wireless antenna and for the side spa remote. The errors have disappeared once and for all. The next step will be to get a new antenna and wireless system that will work through the internet and through my cell phone.
Jun 30, 2012 | Goldline Pool & Spa
My neighbors garage door opener opens my garage door. How do I fix this.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Jul 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door is opening randomly
Mar 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door open by its self
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pool & Spa Logo
109 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
