Question about Samsung Heating & Cooling
SOURCE: I have a wind chaser portable air conditioner
They make a few different 12,000btu models.
Click HERE for the manufacturer's web page to select and download your specific manual.
These error codes are not available in the manual.
Please contact them Monday through Friday, between 8:30 am - 4:30 pm PST,
Toll Free 1-800-405-2943 Inside the US
1-310-827-8615 Outside the US
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
SOURCE: I have a Toyo Aircon
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Posted on Apr 18, 2010
SOURCE: goldstar GP120CE portable air conditioner
Sounds like a clogged condenser pipe which is common for portable Ac . It is usually due to the unit sitting low and collect more pollens an particles at floor level. A pipe cleaner tends to do the trick. Also insects tend to harvest inside the drain pipe
Posted on Jul 15, 2011
Oct 27, 2015 | Heating & Cooling
Jul 09, 2015 | Heating & Cooling
Mar 05, 2015 | Heating & Cooling
Oct 13, 2013 | Kenwood KW85 Air Conditioner
Jun 29, 2011 | Samsung AS18A6RB Air Conditioner
Dec 10, 2010 | Heating & Cooling
Aug 10, 2010 | Fedders A6D24E7D Wall/Window Air...
Mar 14, 2010 | Heating & Cooling
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Aug 02, 2007 | Samsung AW0503B Air Conditioner
61 people viewed this question
