I put after market cd player in but still have wires from the van and the cd player is not working
Did you cut out the factory harness?? You can go down to your local car audio shop and they will have the aftermarket adapter that color codes the cd player wires. You can make the connections to the adapter and then just plug it in to the factorys harness. WalMart might even have the harness for your vehicles make and model. I have a 2000 Voyager and it should use the same harness as yours. The only thing I had to do was find a chassis ground. The factory harness has no ground connection. Here is the no cut aftermarket wiring adapters:
http://www.crutchfield.com/p_120701817/Receiver-Wire-Harness.html?tp=2977
See an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
A little more detail please
